VROGE2
6 years agoQuartus Prime Lite Quitting Unexpectedly During Fitter
I am trying to integrate UART (RS-232 Serial Port) Intel FPGA IP into my project on a DE10-Nano with a Cyclone V SoC. I have followed the CVSOV UART example from the design store and I have gotten to...
- 6 years ago
I was able to get the project to compile after decreasing the total memory size in the On-chip Memory IP in platform designer. I decreased the memory from about 130000 bytes to 100000 bytes and this seemed to work.
Van
AnandRaj_S_Intel
6 years agoOkay, Please click on preview report and attache it.
- VROGE26 years ago
Here it is:
Problem Details Error: Internal Error: Sub-system: U2B, File: /quartus/db/u2b/u2b_av_m10k_param.cpp, Line: 2085 ram_content_index < ram_content.size() Stack Trace: 0x10426: U2B_AV_M10K_PARAM_TRANSLATOR::translate_eram_bitvec + 0x5f6 (db_u2b) 0xf2cf: U2B_AV_M10K_PARAM_TRANSLATOR::convert_config_to_physical_atom + 0x12f (db_u2b) 0xcfb4d: U2B_TRANSLATOR_AV_M10K::convert + 0x9d (db_u2b) 0x349d5: FSV_U2B_POSTFIT::check_u2b_configs_for_conflicts + 0x585 (fitter_fsv) 0x396b9: FSV_U2B_POSTFIT::work + 0x139 (fitter_fsv) 0x601ca3: vpr_qi_u2b_postfit_work + 0xc3 (fitter_vpr20kmain) 0x270376: aa_flow_finalize + 0x66 (fitter_vpr20kmain) 0x26b25d: aa_flow_fit + 0x20d (fitter_vpr20kmain) 0x5735ae: VPR_QI_FACADE::vpr_qi_main + 0x6e (fitter_vpr20kmain) 0x3384e: fitapi_run_vpr + 0x7e (fitter_fitapi) 0x1fb8f: FSV_EXPERT_BASE::run_vpr + 0x13f (fitter_fsv) 0x1f64d: FSV_EXPERT_BASE::place_and_route + 0x12d (fitter_fsv) 0x1eab6: FSV_EXPERT_BASE::invoke_fitter + 0x636 (fitter_fsv) 0x1c952: fsv_execute + 0x22 (fitter_fsv) 0xe910: fmain_start + 0x900 (FITTER_FMAIN) 0x41b1: qfit_execute_fit + 0x1bd (comp_qfit_legacy_flow) 0x5384: QFIT_FRAMEWORK::execute + 0x2a0 (comp_qfit_legacy_flow) 0x267f: qfit_legacy_flow_run_legacy_fitter_flow + 0x1c7 (comp_qfit_legacy_flow) 0x14410: TclInvokeStringCommand + 0xf0 (tcl86) 0x161e2: TclNRRunCallbacks + 0x62 (tcl86) 0x17a65: TclEvalEx + 0xa65 (tcl86) 0xa6f8b: Tcl_FSEvalFileEx + 0x22b (tcl86) 0xa5646: Tcl_EvalFile + 0x36 (tcl86) 0x12606: qexe_evaluate_tcl_script + 0x376 (comp_qexe) 0x11864: qexe_do_tcl + 0x334 (comp_qexe) 0x16755: qexe_run_tcl_option + 0x585 (comp_qexe) 0x380c3: qcu_run_tcl_option + 0x1003 (comp_qcu) 0x160aa: qexe_run + 0x39a (comp_qexe) 0x16e51: qexe_standard_main + 0xc1 (comp_qexe) 0x2233: qfit2_main + 0x73 (quartus_fit) 0x12e98: msg_main_thread + 0x18 (CCL_MSG) 0x1467e: msg_thread_wrapper + 0x6e (CCL_MSG) 0x16660: mem_thread_wrapper + 0x70 (ccl_mem) 0x12761: msg_exe_main + 0xa1 (CCL_MSG) 0x287e: __tmainCRTStartup + 0x10e (quartus_fit) 0x17973: BaseThreadInitThunk + 0x13 (KERNEL32) 0x6a270: RtlUserThreadStart + 0x20 (ntdll) End-trace Executable: quartus_fit Comment: None System Information Platform: windows64 OS name: Windows 10 OS version: 10.0 Quartus Prime Information Address bits: 64 Version: 18.1.0 Build: 625 Edition: Lite EditionVan
