Quartus Prime Lite Quitting Unexpectedly During Fitter
- 6 years ago
I was able to get the project to compile after decreasing the total memory size in the On-chip Memory IP in platform designer. I decreased the memory from about 130000 bytes to 100000 bytes and this seemed to work.
Van
Hi Van,
Try by deleting incremental_db & db folders.
Also close all the application running.
Regenerate the platform designer system and integrate on top and compile.
Also do share your design.
Anand
I have gotten approval and have modified my original code to replace the proprietary sections with a counter. I still get the same error during the compilation
- AnandRaj_S_Intel6 years ago
Not able to replicate the scenario with the project above.
Try by deleting incremental_db & db folders. also check original code.
Anand
- VROGE26 years ago
With that same project I still get the same error as shown below. To be sure I re downloaded the project from the file I posted above. I have deleted the db and incremental_db and I have tried compiling with no other programs running in the background. The only thing that I have been able to do to stop this error from happening is to comment out line 18 in the top level V file or to go into the platform designer in the on chip memory module under memory initialization and un-check "Enable non-default initialization file" and "Initialize memory content". My assumption is that in order for the UART IP to work I need those two boxes to be checked. Is that assumption correct? Could there be any potential problems in where I have it saved or possibly my compilation settings as well? We are running the same version of quartus.
Van
