Quartus Prime Lite Quitting Unexpectedly During Fitter
- 6 years ago
I was able to get the project to compile after decreasing the total memory size in the On-chip Memory IP in platform designer. I decreased the memory from about 130000 bytes to 100000 bytes and this seemed to work.
Van
Hi Van,
Try by deleting incremental_db & db folders.
Also close all the application running.
Regenerate the platform designer system and integrate on top and compile.
Also do share your design.
Anand
I had already tried to delete the db folder but I had not tried to delete the incremental _db folder. I did make some changes in the platform designer in the on chip memory IP. The changes were that I changed the name of the IP's in the platform designer to follow the Max Baud Rate Cyclone V SOC Design Example and I changed the On chip memory initialization so that it does not initialize memory content. this allowed the program to compile but It does not allow for the use of the nios ii code I am using.
Here is my design as it stands now:
I altered the code in NIOS to remove some errors in the hex file, regenerated the platform designer, and re-added the platform designer qip fle and qsys file to my project. The on chip memory is still set to initialize my custom nios project and quartus still stops unexpectedly.
I can't post code at the moment because it contains items which are proprietary and I am awaiting approval to post.
Van
