Trowa's avatar
Trowa
1 year ago
Quartus edition requirement for MAX10 DD device
Hi Sir,
A we know Quartus lite edition are free and can support MAX10 device compilation.
In our reference CRB code base, there is an MAX1050DD device there.
We could not find MAX1050DD device at the device family inside Quartus lite, but it's strange that compilation about the reference code is still fine without error prompting to get the bit stream, sof.
Pls altera/intel help where we can find the device file that Quartus lite can find the device family.
Pls altera/intel comments how we can judge whether the MAX1050DD compiled bit stream is valid or not to use from the Quartus lite edition.
  • FvM's avatar
    FvM
    MAX10 DD types are supported since Quartus 22.1, as far as I see also in Quartus Lite. I checked with most recent 24.1 Lite.
    Frank
  • FvM's avatar
    FvM
    as stated above, you need Quartus 22.1 or newer for MAX10 DD. According to release notes, CentOS 8.2 is required for Quartus 22.1 Linux version. Later Quartus versions seem no to support CentOS at all.
    I notice that CentOS 7.9 support ended mid 2024, you may want to rearrange your tool chain anyway. I'd think about moving to recent Ubuntu version.
    I'd start however with a quick try if Quartus 22.1 is running under Centos 7.9 although not officially supported.
    Regarding MAX10 and Cyclone series support, there's no difference between Quartus Std and Lite version.
    Best regards
    Frank
    • Trowa's avatar
      Trowa
      Hi Frank and Richard,
      Thanks you all.
      I had downloaded 22.1 and 24.1 lite edition, and both are installed fine.
      DD device is recognized fine as well.
  • RichardT_altera's avatar
    RichardT_altera
    I'm pleased to know that your issue has been addressed.
    To add on: CentOS OS support has been deprecated and removed, starting from Quartus version 22.1.
    To check OS support for Quartus, please refer to the webpage below or review the release notes for the specific Quartus version:
    https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/os-support.html#tab-blade-5-5
    https://www.intel.com/content/www/us/en/docs/programmable/683593/22-1/operating-system-support.html
    Do note you may try to install on the non-supported OS but you will have to bear your own risk and there will be no technical support as well.
    The detailed Quartus comparison is here:
    https://www.intel.la/content/dam/www/central-libraries/us/en/documents/2023-11/quartus-prime-comparison-infographic.pdf
    Both Quartus Lite and Standard editions support MAX 10 devices.
    Richard Tan
    RichardT_altera
    Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
    Richard Tan
  • Trowa's avatar
    Trowa
    Hi FvM & RichardTanSY_Altera,
    Thanks for your comments !!
    Since our develop environment is within centos 7.9 x64.
    The original project is started at 21.1
    Currently, i'm testing above projects on lite edition Linux version 21.1.1
    I'm not sure which latest version shall be installed fine under centos 7.9 x64.
    Are there difference of device file between standard or lite edition on 21.1.1 ?
    Is it possible to alter device file from lite to standard to make quartus lite 21.1.1 recognize that max1050dd device ?
    Thank you all.
