Quartus edition requirement for MAX10 DD device
- 1 year ago
Thank you FvM for the answer.
Hi @Trowa ,
Which Quartus Lite version are you using?As mentioned by FvM, the MAX10 DD device is supported starting from Quartus version 22.1 onwards. I recommend to install the latest Quartus Lite version.
Richard Tan
Hi FvM & RichardTanSY_Altera,
Thanks for your comments !!
Since our develop environment is within centos 7.9 x64.
The original project is started at 21.1
Currently, i'm testing above projects on lite edition Linux version 21.1.1
I'm not sure which latest version shall be installed fine under centos 7.9 x64.
Are there difference of device file between standard or lite edition on 21.1.1 ?
Is it possible to alter device file from lite to standard to make quartus lite 21.1.1 recognize that max1050dd device ?
Thank you all.
