palaparthy's avatar
palaparthy
1 month ago
Quartus Eda_Writer keeps crashing
Quartus Prime v25 keeps crashing at the eda_writer step during the flow on Windows 11. I have tried different Quartus versions (II v13.1, Prime Lite v25, Prime Standard v25). All of them crashed at this step multiple times. Is this an issue with the design that I am trying to implement? I searched for this error on Google and I found a message that said it was a bug that was fixed in version 21.1. Strange that its still occuring now in v25 standard.
Problem Details
Error:
Internal Error: Sub-system: WSC, File: /quartus/neto/wsc/wsc_hierarchy_builder.cpp, Line: 1097 m_bp_manager != NULL Stack Trace: 0x48eca: WSC_HIERARCHY_BUILDER::build_map_from_partitions + 0x8a (NETO_WSC) 0x46dd5: WSC_HIERARCHY_BUILDER::build_hierarchy_from_partitions + 0x35 (NETO_WSC) 0x45e1b: WSC_HIERARCHY_BUILDER::build + 0x22b (NETO_WSC) 0x16282: QNETO_START::build_hierarchy_netlist + 0x242 (quartus_eda) 0x28548: QNETO_START::generate_simulation_files + 0x688 (quartus_eda) 0x1a1e3: QNETO_START::generate_eda_files + 0x43 (quartus_eda) 0x33fd0: qneto_execute + 0x210 (quartus_eda) 0xa79b: QNETO_FRAMEWORK::execute + 0x26b (quartus_eda) 0x10b5f: qexe_do_normal + 0x22f (comp_qexe) 0x16fa0: qexe_run + 0x420 (comp_qexe) 0x18012: qexe_standard_main + 0xb2 (comp_qexe) 0x10d17: qneto_main + 0x77 (quartus_eda) 0x12208: msg_main_thread + 0x18 (CCL_MSG) 0x13b18: msg_thread_wrapper + 0x78 (CCL_MSG) 0x15f13: mem_thread_wrapper + 0x73 (ccl_mem) 0x11a41: msg_exe_main + 0xa1 (CCL_MSG) 0x36423: __scrt_common_main_seh + 0x10b (quartus_eda) 0x2e8d6: BaseThreadInitThunk + 0x16 (KERNEL32) 0x8c53b: RtlUserThreadStart + 0x2b (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 25.1std.0
Build: 1129
Edition: Standard Edition
  • KennyT_altera's avatar
    KennyT_altera
    Can you attached your design.qar here for the investigation? Do let me know if you want to share privately.
    • palaparthy's avatar
      palaparthy
      What is a qar file? I don't see it in my Quartus run directory.
        KennyT_altera
        Since there are no update, we shall close this thread.
