Sho2301's avatar
Sho2301
2 years ago
Quartus 21.1 crashing when using the Quartus Programmer to program external QSPI
Hi
I'm having a problem where if try to program a .pof file into a external flash ,which was obtained by converting a .hex file in Quartus, containing the app code for a nios 2 porcessor Quartus repeadetly crashes. This is the problem report i'm getting:
Problem Details
Error:
Internal Error: Sub-system: PGMWQ, File: /quartus/pgm/pgmwq/pgmwq_device_chain.cpp, Line: 2284
element->is_multiple_flash()
Stack Trace:
    0x597e2: PGMWQ_DEVICE_CHAIN::find_total_cfi_device + 0x2a2 (pgm_pgmwq)
    0x7ca2a: PGMWQ_DEVICE_CHAIN::on_update_device_chain + 0x37a (pgm_pgmwq)
    0x8802a: PGMWQ_DEVICE_CHAIN::qt_static_metacall + 0xca (pgm_pgmwq)
   0x1fa79f: QMimeData::urls + 0x13af (Qt5Core)
    0x8f51b: PGMWQ_MANAGER::set_device_chain + 0x5b (pgm_pgmwq)
    0x41311: PGMWQ_DEVICE_TREE::change_file_confirm + 0x8a1 (pgm_pgmwq)
    0x4090e: PGMWQ_DEVICE_TREE::change_file + 0x38e (pgm_pgmwq)
    0x6f216: PGMWQ_FRAME_WND::on_change_file_action + 0x36 (pgm_pgmwq)
     0x7116: QAction::activate + 0x136 (Qt5Widgets)
   0x161ee7: QMenu::actionGeometry + 0x457 (Qt5Widgets)
   0x161d55: QMenu::actionGeometry + 0x2c5 (Qt5Widgets)
   0x167348: QMenu::mouseReleaseEvent + 0xb8 (Qt5Widgets)
    0x3a0a5: QWidget::event + 0x145 (Qt5Widgets)
   0x1635bb: QMenu::event + 0x17b (Qt5Widgets)
    0x179ec: QApplicationPrivate::notify_helper + 0x13c (Qt5Widgets)
    0x156f0: QApplication::notify + 0x7d0 (Qt5Widgets)
   0x1da558: QCoreApplication::notifyInternal2 + 0xb8 (Qt5Core)
    0x18d51: QApplicationPrivate::sendMouseEvent + 0x331 (Qt5Widgets)
    0x62022: QSizePolicy::QSizePolicy + 0x2792 (Qt5Widgets)
    0x60276: QSizePolicy::QSizePolicy + 0x9e6 (Qt5Widgets)
    0x1598e: QApplication::notify + 0xa6e (Qt5Widgets)
    0x5b733: QGuiApplicationPrivate::processMouseEvent + 0x723 (Qt5Gui)
    0x46e0a: QWindowSystemInterface::sendWindowSystemEvents + 0x9a (Qt5Gui)
   0x2273bd: QEventDispatcherWin32::processEvents + 0xbd (Qt5Core)
    0x59b48: qt_plugin_query_metadata + 0x1db8 (qwindows)
   0x1d63b0: QEventLoop::exec + 0x1a0 (Qt5Core)
   0x163af7: QMenu::exec + 0x1c7 (Qt5Widgets)
   0x1638ea: QMenu::exec + 0x1a (Qt5Widgets)
    0x4a1e6: PGMWQ_DEVICE_CHAIN::contextMenuEvent + 0xe6 (pgm_pgmwq)
   0x2e1848: QGraphicsScene::event + 0xe8 (Qt5Widgets)
   0x2f88aa: QGraphicsView::contextMenuEvent + 0x16a (Qt5Widgets)
    0x3a694: QWidget::event + 0x734 (Qt5Widgets)
    0xdcf76: QFrame::event + 0x36 (Qt5Widgets)
   0x302363: QGraphicsView::viewportEvent + 0xa3 (Qt5Widgets)
   0x1dcf03: QCoreApplicationPrivate::sendThroughObjectEventFilters + 0xe3 (Qt5Core)
    0x179d8: QApplicationPrivate::notify_helper + 0x128 (Qt5Widgets)
    0x15f26: QApplication::notify + 0x1006 (Qt5Widgets)
    0x6286e: QSizePolicy::QSizePolicy + 0x2fde (Qt5Widgets)
   0x1d924a: QCoreApplication::exec + 0x14a (Qt5Core)
     0x10bb: qgq_main + 0x8b (quartus)
    0x13638: msg_main_thread + 0x18 (CCL_MSG)
    0x1494e: msg_thread_wrapper + 0x6e (CCL_MSG)
    0x18520: mem_thread_wrapper + 0x70 (ccl_mem)
    0x12df1: msg_exe_main + 0xa1 (CCL_MSG)
     0x20c6: WinMain + 0x156 (quartus)
     0x16d2: __scrt_common_main_seh + 0x116 (quartus)
    0x1257c: BaseThreadInitThunk + 0x1c (KERNEL32)
    0x5af27: RtlUserThreadStart + 0x27 (ntdll)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
Version: 21.1.0
Build: 842
Edition: Standard Edition
