Sho2301
2 years agoQuartus 21.1 crashing when using the Quartus Programmer to program external QSPI
Hi I'm having a problem where if try to program a .pof file into a external flash ,which was obtained by converting a .hex file in Quartus, containing the app code for a nios 2 porcessor Quartus rep...
FvM
2 years agoHi,
I reviewed your other threads, seems like you are connecting the flash through PFL design in MAX10.
https://community.intel.com/t5/Programmable-Devices/External-Flash-not-recognized-by-PFL-and-Quartus-Programmer/m-p/1614195
https://community.intel.com/t5/Programmable-Devices/Programming-external-QSPI-Flash-with-PFL-IP-on-MAX-10-FPGA/m-p/1613580
The relation to your other threads is however unclear, You previously reported "flash not recognized", what has changed inbetween?
It would be much better to append your new findings to the old thread or at least give a link.
