Quartus 21.1 and Blaster 1
At the Moment I`m working with "Quartus 21.1 and Blaster 1", when starting download of the *.pof file, with selected Terasic Blaster 1 USB after 4% an error appears.
With the same cabeling and hardware, Quartus 18.0 works for me?
LOG:
Info (209060): Started Programmer operation at Mon Jan 29 08:48:54 2024
Info (209017): Device 1 contains JTAG ID code 0x031810DD
Info (209016): Configuring device index 1
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Mon Jan 29 08:48:55 2024
Info (209024): Programming device 1
Error (209012): Operation failed <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<This
Info (209061): Ended Programmer operation at Mon Jan 29 08:49:18 2024
Any ideas?
Bop
- NurAiman_M_Intel
Hi Patrick,
While looking for the root cause of your problem, I found below KDB that highlight the same error:
https://www.intel.com/content/www/us/en/support/programmable/articles/000092639.html
We suggest you to use Quartus 19.1 and below for now. Please refer to KDB above.
Aiman
- NurAiman_M_Intel
-Have you also try with Quartus v23.1? Does it work?
-What type of Quartus did you used? Standard?
-What is the device used?
-Can you try to compile a simple design and download a pof file using Quartus 21.0? Does it work?
Aiman
- Bop
Hi Aiman,
Thanks for responding that fast.
I ll try the 23.1.
I use Quartus (Quartus Prime 21.1) Lite Edition.
The final device is a Motor Controller.
U will here from me.
Regards, Patrick
- Bop
Hi Aiman,
unfortunately 23.1 Lite has the same issue with the Blaster 1. Blaster 2 is ordered for further Tests.
--> Info (209060): Started Programmer operation at Wed Jan 31 14:29:36 2024
Info (209060): Started Programmer operation at Wed Jan 31 14:29:37 2024
Info (209061): Ended Programmer operation at Wed Jan 31 14:29:38 2024
Info (209061): Ended Programmer operation at Wed Jan 31 14:30:01 2024Regards, Patrick
- Bop
cancled
- Bop
Hi Aiman,
Thanks for that. This solution works for me with the Blaster 1 and Blaster 2.
Greetings Patrick
- NurAiman_M_Intel
