Quartus 21.1 and Blaster 1
-Have you also try with Quartus v23.1? Does it work?
-What type of Quartus did you used? Standard?
-What is the device used?
-Can you try to compile a simple design and download a pof file using Quartus 21.0? Does it work?
Aiman
Hi Aiman,
Thanks for responding that fast.
I ll try the 23.1.
I use Quartus (Quartus Prime 21.1) Lite Edition.
The final device is a Motor Controller.
U will here from me.
Regards, Patrick
- Bop2 years ago
Hi Aiman,
unfortunately 23.1 Lite has the same issue with the Blaster 1. Blaster 2 is ordered for further Tests.
--> Info (209060): Started Programmer operation at Wed Jan 31 14:29:36 2024
Info (209017): Device 1 contains JTAG ID code 0x031810DD
Info (209060): Started Programmer operation at Wed Jan 31 14:29:37 2024
Info (209016): Configuring device index 1
Info (209007): Configuration succeeded -- 1 device(s) configured
Info (209011): Successfully performed operation(s)
Info (209061): Ended Programmer operation at Wed Jan 31 14:29:38 2024
Info (209024): Programming device 1
Error (209012): Operation failed
Info (209061): Ended Programmer operation at Wed Jan 31 14:30:01 2024Regards, Patrick
- FvM2 years ago
I would compare programmer options of both Quartus installations. Under circumstances it is necessary to disable the on-chip configuration controller during programming.
Which is the involved device, is it MAX10?- Bop2 years ago
Hi, thanks I'll test that.
Yes, it's about 10M02SCE144.
Regards, Patrick
