According to this link:
http://www.altera.com/education/univ/software/unv-software.html 14.0 is the first version that is 64-bit only, so you should be able to use 13.1, although I just looked at my Win7 install for 13.1 and it only lists a 64-bit Quartus. 13.0sp1 has both 32-bit and 64-bit, so go for that :) Cheers, Dave - Altera_Forum
--- Quote Start --- According to this link: http://www.altera.com/education/univ/software/unv-software.html 14.0 is the first version that is 64-bit only, so you should be able to use 13.1, although I just looked at my Win7 install for 13.1 and it only lists a 64-bit Quartus. 13.0sp1 has both 32-bit and 64-bit, so go for that :) Cheers, Dave --- Quote End --- Hey Dave! Thanks! We will try the 13.0 Sp1. I downloaded 14 and then 10 (32 bit friendly) but thought I'd ask before work my way up the list. Jeff - Altera_Forum
Hey Dave!
Thanks for the Help! I downloaded 14 and then 10 (32 bit friendly) and though I'd ask before working my way up the list. Jeff - Altera_Forum
What did you mean, Jeff? Are you using version 10?
I met your same situation. - Altera_Forum
We aren't currently using Quartus.
We designed a "one time" product approx. 10 yrs ago and used MaxPlus II to program the chips. Apparently MaxPlus is no longer supported -> We tried several times and can't get a license for it. The customer has ordered several more units. If we are going to use Quartus, we might as well use the latest and greatest that will run on Win 7 32 bit. - Altera_Forum
--- Quote Start --- If we are going to use Quartus, we might as well use the latest and greatest that will run on Win 7 32 bit. --- Quote End --- If you go to the software download page; https://www.altera.com/download/sw/dnl-sw-index.jsp Click on the Devices tab and select MAX7000, you will find that 13.0sp1 is the last version to support that device. This is a 32-bit version, so you can use that. Cheers, Dave
