anaza3's avatar
anaza3
7 years ago
Problem in using 2 NIOS cores with 2 PLLs and clock sources
I am trying to run two NIOSII cores on an DE0-CV board. They are supposed to run two application and don't need to share any resource. I also need them to run with two different clock rates. This is my design:
***for some reason pictures are unavailable so I am attaching my project.
Image is not available
module DE0_CV_SDRAM_Nios_Test(
      ///////// CLOCK2 /////////
      input              CLOCK2_50,
      ///////// CLOCK3 /////////
      input              CLOCK3_50,
      ///////// CLOCK4 /////////
      inout              CLOCK4_50,
      ///////// CLOCK /////////
      input              CLOCK_50,
      ///////// DRAM /////////
      output      [12:0] DRAM_ADDR,
      output      [1:0]  DRAM_BA,
      output             DRAM_CAS_N,
      output             DRAM_CKE,
      output             DRAM_CLK,
      output             DRAM_CS_N,
      inout       [15:0] DRAM_DQ,
      output             DRAM_LDQM,
      output             DRAM_RAS_N,
      output             DRAM_UDQM,
      output             DRAM_WE_N,
      ///////// GPIO /////////
      inout       [35:0] GPIO_0,
      inout       [35:0] GPIO_1,
      ///////// HEX0 /////////
      output      [6:0]  HEX0,
      ///////// HEX1 /////////
      output      [6:0]  HEX1,
      ///////// HEX2 /////////
      output      [6:0]  HEX2,
      ///////// HEX3 /////////
      output      [6:0]  HEX3,
      ///////// HEX4 /////////
      output      [6:0]  HEX4,
      ///////// HEX5 /////////
      output      [6:0]  HEX5,
      ///////// KEY /////////
      input       [3:0]  KEY,
      ///////// LEDR /////////
      output      [9:0]  LEDR,
      ///////// PS2 /////////
      inout              PS2_CLK,
      inout              PS2_CLK2,
      inout              PS2_DAT,
      inout              PS2_DAT2,
      ///////// RESET /////////
      input              RESET_N,
      ///////// SD /////////
      output             SD_CLK,
      inout              SD_CMD,
      inout       [3:0]  SD_DATA,
      ///////// SW /////////
      input       [9:0]  SW,
      ///////// VGA /////////
      output      [3:0]  VGA_B,
      output      [3:0]  VGA_G,
      output             VGA_HS,
      output      [3:0]  VGA_R,
      output             VGA_VS
//  REG/WIRE declarations
DE0_CV_QSYS u0(
		.clk_1_clk(CLOCK_50),                        //                     clk.clk
		.reset_1_reset_n(1'b1),                  //                   reset.reset_n
		.clk_2_clk(CLOCK2_50),                        //                     clk.clk
		.reset_2_reset_n(1'b0),                  //                   reset.reset_n
		//.key_external_connection_export(KEY), // key_external_connection.export
		//.key2_external_connection_export(KEY), // key_external_connection.export
		//SDRAM
//		.clk_sdram_clk(DRAM_CLK),                  //               clk_sdram.clk
//	   .sdram_wire_addr(DRAM_ADDR),                //              sdram_wire.addr
//		.sdram_wire_ba(DRAM_BA),                  //                        .ba
//		.sdram_wire_cas_n(DRAM_CAS_N),               //                        .cas_n
//		.sdram_wire_cke(DRAM_CKE),                 //                        .cke
//		.sdram_wire_cs_n(DRAM_CS_N),                //                        .cs_n
//		.sdram_wire_dq(DRAM_DQ),                  //                        .dq
//		.sdram_wire_dqm({DRAM_UDQM,DRAM_LDQM}),                 //                        .dqm
//		.sdram_wire_ras_n(DRAM_RAS_N),               //                        .ras_n
//		.sdram_wire_we_n(DRAM_WE_N)                 //                        .we_n
endmodule
When I compile this, it compiles correctly and I can program my board. I use NIOSII to start a HelloWold application. I can successfully run that on core1.
However when I try to run it on core2 I get an error.
Does anybody know what I am doing wrong? I feel there is something wrong with my use of PLLs and clocks sources. But I have no clue what can be wrong. It looked working when I had both processors connected to CLOCK_50 and no PLL.
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    Yes, we can have a Multiprocessor System design without sharing the resource to run with two different clocks.
    Can you attach the project? Is PLL shared?
    Anand
    • anaza3's avatar
      anaza3
      Thank you for the reply. I attached pictures previously but it doesn't show them. I am attaching my project again. The PLL is not shared. I used a PLL for each core. I also used different clock sources and clock pins for each PLL.
      P.s. I know it is possible to use one PLL with two outputs but for the purpose of my research I need to use two different PLLs.
      Thank you,
      Alireza
        AnandRaj_S_Intel
        Hi Alireza,
        I have used your design with DE1-Nano/ Atlas kit, With some modifications(On-chip memory and integer PLL). i was able to run the design successfully.
        Attached the project
        Kindly recompile the cores, top level design and check .
        Anand
  • anaza3's avatar
    anaza3
    I copied the qsf files to my project and successfully compiled it but when I try to compile a helloworld application it gives me error. Do you know what the problem is? should I change the memory addresses?
    nios2-elf-ar -src libhal_bsp.a obj/HAL/src/alt_alarm_start.o obj/HAL/src/alt_busy_sleep.o obj/HAL/src/alt_close.o obj/HAL/src/alt_dcache_flush.o obj/HAL/src/alt_dcache_flush_all.o obj/HAL/src/alt_dcache_flush_no_writeback.o obj/HAL/src/alt_dev.o obj/HAL/src/alt_dev_llist_insert.o obj/HAL/src/alt_dma_rxchan_open.o obj/HAL/src/alt_dma_txchan_open.o obj/HAL/src/alt_do_ctors.o obj/HAL/src/alt_do_dtors.o obj/HAL/src/alt_ecc_fatal_entry.o obj/HAL/src/alt_ecc_fatal_exception.o obj/HAL/src/alt_env_lock.o obj/HAL/src/alt_environ.o obj/HAL/src/alt_errno.o obj/HAL/src/alt_exception_entry.o obj/HAL/src/alt_exception_muldiv.o obj/HAL/src/alt_exception_trap.o obj/HAL/src/alt_execve.o obj/HAL/src/alt_exit.o obj/HAL/src/alt_fcntl.o obj/HAL/src/alt_fd_lock.o obj/HAL/src/alt_fd_unlock.o obj/HAL/src/alt_find_dev.o obj/HAL/src/alt_find_file.o obj/HAL/src/alt_flash_dev.o obj/HAL/src/alt_fork.o obj/HAL/src/alt_fs_reg.o obj/HAL/src/alt_fstat.o obj/HAL/src/alt_get_fd.o obj/HAL/src/alt_getchar.o obj/HAL/src/alt_getpid.o obj/HAL/src/alt_gettod.o obj/HAL/src/alt_gmon.o obj/HAL/src/alt_icache_flush.o obj/HAL/src/alt_icache_flush_all.o obj/HAL/src/alt_iic.o obj/HAL/src/alt_iic_isr_register.o obj/HAL/src/alt_instruction_exception_entry.o obj/HAL/src/alt_instruction_exception_register.o obj/HAL/src/alt_io_redirect.o obj/HAL/src/alt_ioctl.o obj/HAL/src/alt_irq_entry.o obj/HAL/src/alt_irq_handler.o obj/HAL/src/alt_irq_register.o obj/HAL/src/alt_irq_vars.o obj/HAL/src/alt_isatty.o obj/HAL/src/alt_kill.o obj/HAL/src/alt_link.o obj/HAL/src/alt_load.o obj/HAL/src/alt_log_macro.o obj/HAL/src/alt_log_printf.o obj/HAL/src/alt_lseek.o obj/HAL/src/alt_main.o obj/HAL/src/alt_malloc_lock.o obj/HAL/src/alt_mcount.o obj/HAL/src/alt_open.o obj/HAL/src/alt_printf.o obj/HAL/src/alt_putchar.o obj/HAL/src/alt_putcharbuf.o obj/HAL/src/alt_putstr.o obj/HAL/src/alt_read.o obj/HAL/src/alt_release_fd.o obj/HAL/src/alt_remap_cached.o obj/HAL/src/alt_remap_uncached.o obj/HAL/src/alt_rename.o obj/HAL/src/alt_sbrk.o obj/HAL/src/alt_settod.o obj/HAL/src/alt_software_exception.o obj/HAL/src/alt_stat.o obj/HAL/src/alt_tick.o obj/HAL/src/alt_times.o obj/HAL/src/alt_uncached_free.o obj/HAL/src/alt_uncached_malloc.o obj/HAL/src/alt_unlink.o obj/HAL/src/alt_usleep.o obj/HAL/src/alt_wait.o obj/HAL/src/alt_write.o obj/HAL/src/altera_nios2_gen2_irq.o obj/HAL/src/crt0.o obj/alt_sys_init.o obj/drivers/src/altera_avalon_jtag_uart_fd.o obj/drivers/src/altera_avalon_jtag_uart_init.o obj/drivers/src/altera_avalon_jtag_uart_ioctl.o obj/drivers/src/altera_avalon_jtag_uart_read.o obj/drivers/src/altera_avalon_jtag_uart_write.o obj/drivers/src/altera_avalon_sysid_qsys.o obj/drivers/src/altera_avalon_timer_sc.o obj/drivers/src/altera_avalon_timer_ts.o obj/drivers/src/altera_avalon_timer_vars.o
    [BSP build complete]
    Info: Compiling hello_world.c to obj/default/hello_world.o
    nios2-elf-gcc -xc -MP -MMD -c -I../hw_bsp//HAL/inc -I../hw_bsp/ -I../hw_bsp//drivers/inc  -pipe -D__hal__ -DALT_NO_INSTRUCTION_EMULATION -DALT_SINGLE_THREADED    -O0 -g -Wall   -mno-hw-div -mhw-mul -mno-hw-mulx -mgpopt=global  -o obj/default/hello_world.o hello_world.c
    Info: Linking hw.elf
    nios2-elf-g++  -T'../hw_bsp//linker.x' -msys-crt0='../hw_bsp//obj/HAL/src/crt0.o' -msys-lib=hal_bsp -L../hw_bsp/   -Wl,-Map=hw.map   -O0 -g -Wall   -mno-hw-div -mhw-mul -mno-hw-mulx -mgpopt=global  -o hw.elf obj/default/hello_world.o -lm -msys-lib=m
    c:/intelfpga_lite/18.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: address 0xf300 of hw.elf section `.rwdata' is not within region `core2_onchip_memory2'
    c:/intelfpga_lite/18.1/nios2eds/bin/gnu/h-x86_64-mingw32/bin/../lib/gcc/nios2-elf/5.3.0/../../../../../H-x86_64-mingw32/nios2-elf/bin/ld.exe: address 0x10ec0 of hw.elf section `.bss' is not within region `core2_onchip_memory2'
    collect2.exe: error: ld returned 1 exit status
    make: *** [hw.elf] Error 1
    Alireza
  • anaza3's avatar
    anaza3
    I resolved the compilation problem by increasing the size of onchip memory and base addresses. But my original problem still exists.
    The problem still exists.! I can run hello world on core1 but I face error in when I run it on core2. It looks the picture you posted also shows success on core1 but problem is core2. I am attaching my new project as well which I generated by using your qsf files.
    Alireza
      AnandRaj_S_Intel
      Hi Alireza,
      Check the core 2 reset signal.
      i.e .reset_2_reset_n(1'b0) should be .reset_2_reset_n(1'b1),
      Anand
  • anaza3's avatar
    anaza3
    Thanks. Can I ask another question? Do you know if it is possible in this design to share the SDRAM ? not to share data with each other but to partition it and assign half of the SDRAM to each core.
    Alireza
