Problem in using 2 NIOS cores with 2 PLLs and clock sources
Yes, we can have a Multiprocessor System design without sharing the resource to run with two different clocks.
Can you attach the project? Is PLL shared?
Anand
Thank you for the reply. I attached pictures previously but it doesn't show them. I am attaching my project again. The PLL is not shared. I used a PLL for each core. I also used different clock sources and clock pins for each PLL.
P.s. I know it is possible to use one PLL with two outputs but for the purpose of my research I need to use two different PLLs.
Thank you,
Alireza
- AnandRaj_S_Intel7 years ago
Hi Alireza,
I have used your design with DE1-Nano/ Atlas kit, With some modifications(On-chip memory and integer PLL). i was able to run the design successfully.
Attached the project
Kindly recompile the cores, top level design and check .
Anand
