anaza3
7 years agoProblem in using 2 NIOS cores with 2 PLLs and clock sources
I am trying to run two NIOSII cores on an DE0-CV board. They are supposed to run two application and don't need to share any resource. I also need them to run with two different clock rates. This is ...
anaza3
7 years agoHi,
Thank you for the reply. I attached pictures previously but it doesn't show them. I am attaching my project again. The PLL is not shared. I used a PLL for each core. I also used different clock sources and clock pins for each PLL.
P.s. I know it is possible to use one PLL with two outputs but for the purpose of my research I need to use two different PLLs.
Thank you,
Alireza
AnandRaj_S_Intel
7 years agoHi Alireza,
I have used your design with DE1-Nano/ Atlas kit, With some modifications(On-chip memory and integer PLL). i was able to run the design successfully.
Attached the project
Kindly recompile the cores, top level design and check .
Anand
