12 years agoproblem (?) using shared variables
I need your kind opinion. Please, anyone explain me why the following code is not running. VHDL code (sel-explainable)
entity counter_with_sharedvar is
port (clk: in bit;
digit1, digit2: out integer range 0 to 9);
end entity;
architecture counter of counter_with_sharedvar is
shared variable temp1, temp2: integer range 0 to 9;
begin
proc1: process (clk)
begin
if (clk'EVENT and clk='1') then
if (temp1=9) then
temp1 := 0;
else
temp1 := temp1 + 1;
end if;
end if;
end process proc1;
proc2: process (clk)
begin
if (temp1=9) then
if (temp2=9) then
temp2 := 0;
else
temp2 := temp2 + 1;
end if;
end if;
end if;
end process proc2;
digit1 <= temp1;
digit2 <= temp2;
end architecture;
VHDL testbench code
entity tb_cct is
end entity tb_cct;
architecture arch of tb_cct is
constant T: time := 20 ns;
signal t_clk: bit;
signal t_d1: integer range 0 to 9;
signal t_d2: integer range 0 to 9;
begin
uut: entity work.counter_with_sharedvar(counter)
port map(clk => t_clk, digit1 => t_d1, digit2 => t_d2);
process
begin
t_clk <= '0';
wait for T/2;
t_clk <= '1';
wait for T/2;
end process;
end arch;
simulation result (50 MHz oscilator) https://www.alteraforum.com/forum/attachment.php?attachmentid=7548 Any ideas? Regards Jaraqui
