13 years agoproblem (?) using shared variables
Hi, I need your kind opinion. Please, anyone explain me why the following code is not running. VHDL code (sel-explainable)
en...
13 years ago --- Quote Start --- Ill give you the outline - its very similar to what you're doing:
process(clk)
begin
if rising_edge(clk) then
cnt <= cnt + 1;
if cnt = N then -- this will give you an enable rate of clk/N
clk_en <= '1';
else
clk_en <= '0';
end if;
if clk_en = '1' then
--do something once every N clocks
end if;
end process;
--- Quote End --- Forgetting momentarily the shared variables stuff and concentrating only in a simple clock generator based on this piece of code you provided, I developed the following code:
library ieee;
use ieee.std_logic_1164.all;
entity clock_gen is
generic(N: integer := 50_000_000);
port(
mclk: in std_logic;
rst: in std_logic;
clk: out std_logic);
end clock_gen;
architecture arch of clock_gen is
signal cnt: integer := 0;
signal clk_en: integer := 0;
signal state: integer := 0;
begin
process(mclk, rst)
begin
if(rst = '1') then
cnt <= 0;
clk_en <= 0;
state <= 0;
elsif(rising_edge(mclk)) then
cnt <= cnt + 1;
if(cnt = N) then -- this will give you an enable rate of clk/N
clk_en <= 1;
else
clk_en <= 0;
end if;
if(clk_en = 1) then --do something once every N clocks
if(state = 0) then
clk <= '1';
state <= 1;
else
clk <= '0';
state <=0;
end if;
end if;
end if;
end process;
end arch;
Implementing it to blink a simple led receiving clk at expected 1 Hz, this doesn´t work. The led blinks (full period) at every 174 seconds. This period stay fixed no matter N is changed. Any idea? Regards Jaraqui
