13 years agoproblem (?) using shared variables
Hi, I need your kind opinion. Please, anyone explain me why the following code is not running. VHDL code (sel-explainable)
en...
13 years agoI know - and its only for simulation. A protected type is a bit like a class in C++. They contain member variables, functions and procedures and can be extremly useful for behavioural modelling. In VHDL 2002, they made it a LRM rule that shared variables MUST be protected types, but as this would break old VHDL '93 code, and so by default it only throws a warning (you can make it stricter though).
so, as an example:
type DDR_model_t is protected
procedure write_data(addr : integer; data : std_logic_vector);
impure function read_data(addr: integer) return std_logic_vector;
end proteted DDR_Model_t;
type ddr_model_t is protected body
type mem_row_t is array(0 to 1023) of std_logic_vector(31 downto 0);
type mem_row_ptr_t is access mem_row_t;
type mem_bank_t is array(0 to 1023) of mem_row_ptr_t;
type mem_bank_ptr_t is access mem_bank_t;
type mem_t is array(0 to 7) of mem_bank_ptr_t;
variable mem : mem_t;
procedure write_data(addr: integer; data : std_logic_vector) is
variable bank, row, col : integer;
begin
bank = addr rem 8;
row = (addr/8)/1024;
col = (addr rem 1024);
if mem(bank) = null then
mem(bank) := new mem_bank_t;
end if;
if mem(bank)(row) = null then
mem(bank)(row) := new mem_row_t;
end if;
mem(bank)(row)(col) := data;
end procedure write_data;
impure function read_data(addr: integer) return std_logic_vector is
CONSTANT ALL_U : std_logic_vector(31 downto 0) := (others => 'U');
begin
bank = addr rem 8;
if mem(bank) = null or mem(bank)(row) = null then
return ALL_U;
else
return mem(bank)(row)(col);
end if;
end function read_data;
end protected ddr_model_t;
shared variable ddr_model : ddr_model_t;
--to use it:
ddr_model.write_data(a);
some_var := ddr_model.read_data(b);
And then wrap an entity around this shared variable to make it behave like a DDR chip, but it will only use system ram as individual rows are accesses, so you dont need to use a massive amount of ram during simulation to model the memory, and it runs much faster.
