13 years agoproblem (?) using shared variables
Hi, I need your kind opinion. Please, anyone explain me why the following code is not running. VHDL code (sel-explainable)
en...
13 years agoTricky,
Without your help, without the help from another collegue from another forum, without the collaboration of another collegue from here (variable initialization), it couldn´t be possible for me to exit from step zero to step one. And I thank you for this. I thank also all the people here for the "temperature" in this forum. The objectivity of the problem stay fixed, withou any extreme "ego" unecessary discussions. Of course the "nerd-Big-Bang-theory-discussion" must exist because is part of us. This kind of discussion is obviously different from the former cited. I think all we enter in this type discussion at some moment, even when the impulse is involutary. Two paragraphs of "speech" to do an invitment. I like posts such this because the code is small and easly reproductible and we talking about only one specific problem. Someone who googles the problem can find here the solution. To finish gracefully, to eliminate the last "evil", it is necessary to generate a 1 Hz clock without logic, as Tricky and other people already did recommend. Can someone who is interested (and knows how to do it) modificate this last version with the so called clock enabling version (plus initializing temp1/temp2). Is it dificult? I ask this because I don´t know how to do at this time (I will look for good books or expect someone recommend one...). Let me know if someone can do! Regards Jaraqui
