preserve logic or insert internal buffer
Hi
is there any attribute to keep 2 consecutive NOT gate in synthesis ? some kind of preserve attribute , what I have found is preserving registers but logic gate (LUT)
OR
other option is there away to push a "Internal" Buffer which will be kept in the synthesis process ?
Or.
Hi Or,
Do the above comments help?
Nurina
- roeekalinsky
Contributor
Hi Or,
You can set the "keep" attribute on the signals that are the outputs of the inversions to prevent Quartus from optimizing them away. See:
BTW, I'm not sure why you'd want to do this. If you're trying to cascade inverters to create a delay chain, then there's almost certainly a better way to go about whatever it is you're ultimately trying to accomplish.
Cheers,
-Roee
- OrF
Hi Roee,
thanks for the fast response ,
I DO want to cascade inverters to create delay chain - since we are trying to build a-sync design.
any better way to create delay between logic cells ?
Or.
- roeekalinsky
Contributor
Hi Or,
I don't have any better suggestion for you toward that intent.
My broader advice would be to stick to synchronous design unless you have a very good reason to go async, and there is almost never a good reason to go async. Especially in an FPGA.
But there are rare exceptions. If you do have a good reason for going async, good luck! You're living on the edge ; -)
-Roee
- sstrell
Yeah, relying on delay like that is really not recommended. Just synch to a clock domain. Add a counter if the delay needs to be more than a single clock cycle.
- Nurina
Hi Or,
Nurina
