OrF
3 years agopreserve logic or insert internal buffer
Hi is there any attribute to keep 2 consecutive NOT gate in synthesis ? some kind of preserve attribute , what I have found is preserving registers but logic gate (LUT) OR other option is the...
- 3 years ago
Hi Or,
Do the above comments help?
Nurina
OrF
3 years agoHi Roee,
thanks for the fast response ,
I DO want to cascade inverters to create delay chain - since we are trying to build a-sync design.
any better way to create delay between logic cells ?
Or.
- roeekalinsky3 years ago
Contributor
Hi Or,
I don't have any better suggestion for you toward that intent.
My broader advice would be to stick to synchronous design unless you have a very good reason to go async, and there is almost never a good reason to go async. Especially in an FPGA.
But there are rare exceptions. If you do have a good reason for going async, good luck! You're living on the edge ; -)
-Roee
