14 years ago
port width definition by generic
Hi all
another question in my quest to switch from graphical tools to pure VHDL :)
let's say I have a DFF and I want the D and Q ports to be defined by a generic.
I know how to define it in the component, but how do I instantiate it?
when I use the generic to define the generic in the top level, it is not defined...
    In the top level, you can refer to the default values in the generic port or constants defined in a package.
    The same way you define the ports in your instantiation.
    entity DFF_reg is
    generic (
    WIDTH_g : integer := 1
    port (
    clk_p : in std_logic;
    data_in_p : in std_logic_vector(WIDTH_g-1 downto 0);
    data_out_p : out std_logic_vector(WIDTH_g-1 downto 0)
    end DFF_reg;
    example instantiation:
    signal data_in_s : std_logic_vector(2 downto 0);
    signal data_out_s : std_logic_vector(2 downto 0);
    U1 : DFF_reg
    generic map (
    WIDTH_g => 3
    port map (
    clk_p => clk_p,
    data_in_p => data_in_s,
    data_out_p => data_out_s
    If you have generics on your top-level entity, they can be set in Quartus using Tcl commands. For example, a design with a timestamp and version register can have the contents defined via
    #  Build timestamp#   - Tcl  returns the same as
    set timestamp
    puts " - Build timestamp  ($timestamp 0x)"
    #  Version (integer format)
    set version
    #  Generics
    set_parameter -name VERSION   $version
    set_parameter -name TIMESTAMP $timestamp
    Cheers,
    Dave
    --- Quote Start ---
    entity DFF_reg is
    generic (
    port (
    end DFF_reg;
    U1 : DFF_reg
    generic map (
    WIDTH_g => 3
    port map (
    clk_p => clk_p,
    --- Quote End ---
    Will a vector of 0 downto 0 compile? I know I've had problems with arrays like that.
    --- Quote Start ---
    --- Quote End ---
    Yes, its fine.
    You can implement the port assignment to a std_logic using the std_logic_vector with an index, i.e.,
    port map (
    port_slv(0) => port_sl
    Cheers,
    Dave
    --- Quote Start ---
    set timestamp
    set version
    #  Generics
    Cheers,
    Dave
    --- Quote End ---
    Thank you all it was easier then thought :)
    dwh, using tcl is one more thing I need to learn...
    you mean that from the tcl I can change the value of generic?
    so in your example VERSION and TIMESTAMP are defined in the VHDL code as generics, std_logic_vector or custom type?
    Cool!
    --- Quote Start ---
    --- Quote End ---
    The generics were integers, and then down in the control registers code, the integers are changed to std_logic_vector.
    Generics can be set from the command-line in Modelsim as well. This is useful for changing timescales, eg. lets say in hardware you blink an LED every 0.5s. To test this in simulation, you'd have to simulate for several seconds. If instead you have a generic real value for the blink time, you can set it to 0.5 for synthesis and 1.0e-6 for simulation. Since the generic can be over-ridden by both tools, there is no need to edit the code, eg., the code can have a default setting for the generic of 0.5.
    Cheers,
    Dave
