14 years ago --- Quote Start --- The same way you define the ports in your instantiation. entity DFF_reg is generic ( WIDTH_g : integer := 1 ); port ( clk_p : in std_logic; data_in_p : in std_logic_vector(WIDTH_g-1 downto 0); data_out_p : out std_logic_vector(WIDTH_g-1 downto 0) ); end DFF_reg; example instantiation: signal data_in_s : std_logic_vector(2 downto 0); signal data_out_s : std_logic_vector(2 downto 0); U1 : DFF_reg generic map ( WIDTH_g => 3 ) port map ( clk_p => clk_p, data_in_p => data_in_s, data_out_p => data_out_s ); --- Quote End --- Will a vector of 0 downto 0 compile? I know I've had problems with arrays like that.
