15 years ago
Newbie question about SDC in Timing analyzer
Hi all,
This is my first project in verilog, in Altera and in Cyclone 2 FPGA.
I have many modules and when i try to connect the modules there are setup and hold problems occurred. Somehow by referring to quartus document i solved those by analysing in time quest timing analyzer. If i look at "Unconstrained paths Summary" in timing analyzer there are unconstrained clock, unconstrained input port, unconstrained input port path, unconstrained output port and unconstrained output port path.
From the quartus document i came to know that these things can be solved by setting input delay and output delay, but i dont know how to calculate those delays because this is occuring when modules are interconnected. How can i solve this? Any help is appreciated.
Thank you
    Thank you for the info.
    I need a confirmation about unconstrained clocks.
    I have created system clock by using create_clock and create_generated_clock.
    As rbugalho said there are unconstrained clocks but the Target where
    its showing are the modules where i am just using the system clock, it has nothing to do with clock generation.
    How to solve that problem?
    Is it again related to create_clock or create_generated_clock?
    --- Quote Start ---
    --- Quote End ---
    you have to evaluate the unconstrainted "clocks" carefully. Are they really clocks or gate signals for some other clocks ? If these are independent clock you have to use the create-clock, if they are derived from other clocks use create_generated_clock. BTW
    In timequest you can generate a Clock transfer Report. In this report you will find all your paths between your clock domains. Check if some of the pathe are false paths.
    Kind regards
    GPK
    Blackpulsor,
    from my experience, the unconstrained clocks you are seeing in the report are ripple or gated clocks, generated somewhere in your design, that you have not constrained.
    The STA will automatically notice that these signals are being used as clocks but that you have not defined their constraints.
    Are you sure your modules are not generating ripple clocks or gating clocks inside those modules?
    If this is the case, you're missing a create_generate_clock blabla for each of those cases.
    Thank you for all the valuable suggestions.
    Considering the above things, i rechecked and finally
    i solved the issue.
