16 years ago --- Quote Start --- Thank you for the info. I need a confirmation about unconstrained clocks. I have created system clock by using create_clock and create_generated_clock. As rbugalho said there are unconstrained clocks but the Target where its showing are the modules where i am just using the system clock, it has nothing to do with clock generation. How to solve that problem? Is it again related to create_clock or create_generated_clock? --- Quote End --- Hi, you have to evaluate the unconstrainted "clocks" carefully. Are they really clocks or gate signals for some other clocks ? If these are independent clock you have to use the create-clock, if they are derived from other clocks use create_generated_clock. BTW In timequest you can generate a Clock transfer Report. In this report you will find all your paths between your clock domains. Check if some of the pathe are false paths. Kind regards GPK
