17 years agoNew to VHDL. Help with errors
Can you tell me why im getting these errors for this code:
LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_unsigned.all; ENTITY DAC2 IS PORT( hardwarecontrol: IN STD_LOGIC; -- Control Hardware Shut Down input: IN STD_LOGIC_VECTOR (11 DOWNTO 0); -- Input Value for sine wave clock: IN STD_LOGIC; -- Clock Input from Altera Board cs: OUT STD_LOGIC; -- Chip Select sck: OUT STD_LOGIC; -- Serial Clock Input sdi: OUT STD_LOGIC; -- Serial Data Input ldac: OUT STD_LOGIC; -- Latch DAC Input shdn: OUT STD_LOGIC -- Hardware Shutdown Input ); END DAC2; ARCHITECTURE behaviour OF DAC2 IS SIGNAL count: STD_LOGIC_VECTOR (3 DOWNTO 0); BEGIN sck <= clock; IF RISING_EDGE(clock) THEN IF (hardwarecontrol = '1') THEN cs <= '0'; ldac <= '1'; PROCESS(clock,input) BEGIN IF (count = "0000") THEN sdi <= '0'; ELSIF (count = "0001") THEN sdi <= '1'; ELSIF (count = "0010") THEN sdi <= '0'; ELSIF (count = "0011") THEN sdi <= '1'; ELSIF (count = "0100") THEN sdi <= input(11); ELSIF (count = "0101") THEN sdi <= input(10); ELSIF (count = "0110") THEN sdi <= input(9); ELSIF (count = "0111") THEN sdi <= input(8); ELSIF (count = "1000") THEN sdi <= input(7); ELSIF (count = "1001") THEN sdi <= input(6); ELSIF (count = "1010") THEN sdi <= input(5); ELSIF (count = "1011") THEN sdi <= input(4); ELSIF (count = "1100") THEN sdi <= input(3); ELSIF (count = "1101") THEN sdi <= input(2); ELSIF (count = "1110") THEN sdi <= input(1); ELSIF (count = "1111") THEN sdi <= input(0); cs <= '1'; ldac <= '0'; shdn <= '1'; END IF; count <= count +1; END PROCESS; ELSIF (hardwarecontrol = '0') THEN count <= "0000"; END IF; END IF; END behaviour; Error (10500): VHDL syntax error at DAC2.vhd(26) near text "IF"; expecting "end", or "(", or an identifier ("if" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at DAC2.vhd(26) near text "THEN"; expecting "(", or "'", or "." Error (10500): VHDL syntax error at DAC2.vhd(27) near text "THEN"; expecting "<=" Error (10500): VHDL syntax error at DAC2.vhd(85) near text "ELSIF"; expecting "end", or "(", or an identifier ("elsif" is a reserved keyword), or a concurrent statement Error (10500): VHDL syntax error at DAC2.vhd(85) near text "THEN"; expecting "<=" Error (10500): VHDL syntax error at DAC2.vhd(87) near text "IF"; expecting ";", or an identifier ("if" is a reserved keyword), or "architecture
