Altera_ForumHonored Contributor16 years agoNew to VHDL. Help with errors Can you tell me why im getting these errors for this code: LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_unsigned.all; ENTITY DAC2 IS PORT( hardwarecontrol: IN STD_LOG...Show More
Altera_ForumHonored Contributor16 years agoSo it's not possible to start the process in an if statement?
Recent DiscussionsInterfacing Avalon Streaming FIFO IP with GTS Ethernet Hard IPInvalid license key (inconsistent authentication code)Regarding the issue of UFM not startingram retimingReset Release IP for Agilex needs Stratix 10 device files installed!
