13 years ago
My clock port cannot be matched as a port
I need information about the critical path in my circuit. I first tried to use Quartus II 9.1 with classical timing analyzer but I obtained
the warning message "No paths found for timing analysis". Now I'm trying with the new version Quartus II 12.1 sp1.
This is my top entity vhdl code
library ieee;
use ieee.std_logic_1164.all;
use work.my_types.all;
entity qc_enc is
    generic(    N: positive := 20;
                K: positive := 10;
                L: positive := 5);
    port(
        CLOCK_50:    IN std_logic;
        KEY:            IN std_logic_vector(0 downto 0); -- reset_n
        GPIO_0:        IN std_logic_vector(K-1 downto 0); -- u
        GPIO_1:        OUT std_logic_vector(2*L-1 downto 0));--p_ij
end qc_enc;
This is the mapping on the Pin Planner window:
https://www.alteraforum.com/forum/attachment.php?attachmentid=6863
I've tried to create a clock in TimeQuest Timing Analyzer with the command
create_clock -name clock -period 20.000
receiving the following errors:
  Ignored filter: CLOCK_50 could not be matched with a port
Ignored create_clock: Argument <targets> is an empty collection
In fact it is not present in the list of all ports:
https://www.alteraforum.com/forum/attachment.php?attachmentid=6862
Furthermore I have not any port called LVDS150p/nCEO.
Thanks in advance for your help.
    Hmm, that is weird then. I would ask if you've actually used it as a clock, but your RTL view implies you are.
    Could you post the body of your code please.
    Before synthesis, its always a good idea to check the functionality of your logic using Modelsim and a testbench. If you've got a logical error that causes Quartus to determine that CLOCK_50 is not used for anything, then perhaps it is eliminating the clocked logic, and hence you no longer have a clock in your design.
    And looking at your warnings file:
    Warning (15610): No output dependent on input pin "CLOCK_50"
    You see your problem :)
    Cheers,
    Dave
    --- Quote Start ---
    I already did the testbench and it works properly, but then I slightly modified one component that was not synthesizable (a ram that loads its content from a text file).
    --- Quote End ---
    So what happens when you test the modified code with the testbench?
    Don't post code inline. No one really wants to read it. If you want someone to look at the problem, post a zip file with the project and a synthesis Tcl script, or post a .qar file.
    Cheers,
    Dave
    Ok, I opened the design and synthesized it and it uses no logic cells.
    If there are no logic cells, then no clock is required :)
    Sorry, I don't have time to look at your code in detail. All I can recommend is that you synthesize each component in your hierarchy and make sure each needs logic.
    One common mistake to look for is that your reset logic is inverted. However, that type of mistake would be picked up in simulation too.
    Good luck!
    Cheers,
    Dave
    --- Quote Start ---
    What do you mean for logic ? Registers/flip-flop ?
    --- Quote End ---
    Look at the hierarchy display in Quartus, it has a horizontal slider bar. Scroll that bar over and it tells you how many logic cells, registers, RAM blocks, DSP blocks, etc your design uses.
    Use that to track down whether your parts synthesize correctly.
    Cheers,
    Dave
    Thank you so much for your help. I tried to compile one component at a time and the problem is the "g_ram" component. It uses 0 logic elements and I received this warning "Warning (10631): VHDL Process Statement warning at g_ram.vhd(18): inferring latch(es) for signal or variable "ram", which holds its previous value in one or more paths through the process".
    The only way to have the component ROM compiled correctly is to use:
    	subtype word_t is std_logic_vector(7 downto 0);
    	type memory_t is array(127 downto 0) of word_t;
    or
    	type memory_t is array(255 downto 0) of word_t;
    In all other cases it is not able to create a memory (Memory bits = 0 and M4Ks = 0) and gives the warning "No clocks defined in design".
    Is this normal ?
    The Quartus Handbook and GUI have the syntax for inferred RAM - are you using the Altera recommended procedure?
    Personally I just use the altsyncram component, then there is no ambiguity as to what I am asking for.
    Cheers,
    Dave
    Yes but I think you have to use the internal memories. You cannot crete a generic size memory.
    --- Quote Start ---
    --- Quote End ---
    You're using an FPGA, so there is no support for a generic size memory. Your inferred memory has to match what exists inside the FPGA.
    Cheers,
    Dave
