13 years agoThank you so much for your help. I tried to compile one component at a time and the problem is the "g_ram" component. It uses 0 logic elements and I received this warning "Warning (10631): VHDL Process Statement warning at g_ram.vhd(18): inferring latch(es) for signal or variable "ram", which holds its previous value in one or more paths through the process".
