10 years agoModelsim won't compiles VHDL -> Unexpected signal: 11
Hi Altera,
some Modelsim versions (10.3c and 10.1e) won't completely compile the following VHDL code.library ieee;
use ieee.std_logic_1164.all;
entity x is
generic (signal_count : natural := 1);
port (clock : in std_logic);
end entity;
architecture rtl of x is
type t_signal_array is array (signal_count - 1 downto 0) of std_logic_vector (2 downto 0);
type reg_mclk_t is record
ddr_chain : t_signal_array;
output : std_logic_vector(signal_count - 1 downto 0);
end record;
signal mclk_r : reg_mclk_t;
signal mclk_r_in : reg_mclk_t;
begin
MCLK_PROC: process (clock, mclk_r_in)
begin
if rising_edge (clock) then
mclk_r.ddr_chain(signal_count - 1 downto 0)(2 downto 1) <= mclk_r_in.ddr_chain(signal_count - 1 downto 0)(2 downto 1); -- this line results in# ** Fatal: Unexpected signal: 11.
--mclk_r.ddr_chain(signal_count - 1 downto 0) <= mclk_r_in.ddr_chain(signal_count - 1 downto 0); -- this works
--mclk_r.ddr_chain(signal_count - 1 downto 0)(1) <= mclk_r_in.ddr_chain(signal_count - 1 downto 0)(1); -- this works
--mclk_r.ddr_chain(signal_count - 1 downto 0)(2) <= mclk_r_in.ddr_chain(signal_count - 1 downto 0)(2); -- this works
mclk_r.output <= mclk_r_in.output;
end if;
end process;
end rtl; Syntax checking passes all verifications, but when it comes to writing the library data to file system compile process stops with following message. --- Quote Start --- # vcom -work work -2002 -explicit -stats=none C:/work/VHDL-Sims/Test_unexpectedSignal.vhd# Model Technology ModelSim ALTERA vcom 10.3c Compiler 2014.09 Sep 20 2014# -- Loading package STANDARD# -- Loading package TEXTIO# -- Loading package std_logic_1164# -- Compiling entity x# -- Compiling architecture rtl of x# ** Fatal: Unexpected signal: 11.# ** Error: C:/work/VHDL-Sims/Test_unexpectedSignal.vhd(34): VHDL Compiler exiting --- Quote End --- Library view of ModelSim shows the new entity inside the library. However elaborating this entity and loading it into a simulation fails. Even the library files on disk won't be created, thus elaboration can't find them. Is there a specific reason for this or is it just a bug in ModelSim?7 Replies
Looks like a Modelsim bug. Fatals like that without a decent explanation usually are.
Have you tried 10.4c? (the latest version) If it still fails with latest you need to raise a ticket with mentor (not altera) - Altera_Forum
Thank you for the clarification. I wasn't sure if modelsim altera edition is managed by altera or by mentor.
I haven't got the 10.4c for now, but testing with 10.4b shows the same behavior. Let's see what mentor says to this. - Altera_Forum
Ive compiled it in Questa 10.4c and 10.3c and didnt see a problem
Have you tried compiling in a clean folder? How are you compiling the file? - Altera_Forum
Interesting that Questa doesn't have this problem.
So far i tried to compile it within a ModelSim project, outside a project file environment and into a clean newly created work library. It doesn't changes the result and always comes up with the signal 11. Only if i change the source from the double array range code to a single array access with individual bit access it compiles. - Altera_Forum
The questa ref manual gives exit 11 as "11 General language syntax error"
Again - this is a defect. You need to raise the issue with altera.
Ok thank you for your support. I just filed an service request to altera.
