Modelsim is not simulating.
I have a module I want to test
out_control.vhd
entity OUT_CONTROL is port ( CLK : in std_logic; RST : in std_logic; OUT_MASK : in std_logic_vector(55 downto 0); OUT_ON_OFF : in std_logic_vector(55 downto 0); OUT_TRIG : in std_logic; OUTPUTS : out std_logic_vector(55 downto 0) ); end entity OUT_CONTROL; architecture behavior of OUT_CONTROL is type OutStateType is (ST_IDLE, ST_SET); signal OutState : OutStateType := ST_IDLE; begin process(CLK) begin if (rising_edge(CLK)) then case OutState is when ST_IDLE => if (OUT_TRIG = '1') then OutState <= ST_SET; end if; when ST_SET => for i in 0 to 55 loop if (OUT_MASK(i) = '1') then OUTPUTS(i) <= OUT_ON_OFF(i); end if; end loop; OutState <= ST_IDLE; when others => OutState <= ST_IDLE; end case; end if; end process; end behavior;
And a test bench
out_control_tb.vhd
entity out_control_tb is end entity; architecture test of out_control_tb is component OUT_CONTROL is port ( CLK : in std_logic; RST : in std_logic; OUT_MASK : in std_logic_vector(55 downto 0); OUT_ON_OFF : in std_logic_vector(55 downto 0); OUT_TRIG : in std_logic; OUTPUTS : out std_logic_vector(55 downto 0) ); end component; signal reset : std_logic := '0'; signal clock : std_logic; signal s_out_mask : std_logic_vector(55 downto 0); signal s_on_off : std_logic_vector(55 downto 0); signal s_outputs : std_logic_vector(55 downto 0); signal s_out_trig : std_logic; signal stop : boolean; begin U_OUT_CONTROL : OUT_CONTROL port map ( CLK => clock, RST => reset, OUT_MASK => s_out_mask, OUT_ON_OFF => s_on_off, OUT_TRIG => s_out_trig, OUTPUTS => s_outputs ); clkgen : process begin while true loop clock <= '0'; wait for 10 ns; clock <= '1'; wait for 10 ns; end loop; wait; end process; process begin if (rising_edge(clock)) then wait for 100 ns; s_out_mask <= X"0000000000000F"; s_on_off <= X"0000000000000F"; s_out_trig <= '1'; wait for 20 ns; s_out_trig <= '0'; s_on_off <= X"00000000000003"; s_out_trig <= '1'; wait for 20 ns; s_out_trig <= '0'; wait; end if; end process; end architecture;
Now I do
1. open a new project in Modelsim
2. add files out_control.vhd and out_control_tb.vhd
3. compile files successfully
4. Simulation -> Start Simulation -> select work/out_control_tb.vhd
5. Add signals to a Wave view.
6. Press Run ( Run continuous) button.
I see
VSIM 23>run (VSIM 24>run - continue)
And nothing. No signals appear on the Wave tab.
What do I do wrong?
- sstrell
I think you have to say run -all to advance the simulation.
- YEan
Contributor
Hi there,
Do you have any update on your problem?
Thank you
Ean- EEren
Well...Some problems I resolved another pop up.
For example
process begin reset <= '1'; wait for 100 ns; reset <= '0'; wait until s_send_rdy = '1'; s_send_data <= X"88"; s_send_trig <= '1'; wait for 40 ns; s_send_trig <= '0'; wait until s_send_rdy = '0'; wait until s_send_rdy = '1'; s_send_data <= X"ED"; s_send_trig <= '1'; wait for 40 ns; s_send_trig <= '0'; wait until s_send_rdy = '0'; wait; end process;And I see
Is wait until working directive?
- YEan
Contributor
What does that mean working directive?
- sstrell
wait until doesn't exist in Verilog. Quick Google search for a replacement:
https://stackoverflow.com/questions/12370324/verilog-equivalent-of-wait-until-for
- EEren
Who is talking about Verilog ???!!!
Where do you see a single line of Verilog in my code ???!!!
Jesus Christ!!! Unbelievable!!!
