12 years agoModelSim incorrectly simulates FPGA design
My AHDL program runs as expected on my FPGA, but when I simulate it in ModelSim, the result is wacky.
Tools/Equipment: Windows 7 Quartus II 32-bit v12.0 sp2 Web Edition ModelSim SE-64 10.0c, using Gate Level Simulation, VHDL compiled library FPGA: Cyclone III EP3C16F484C8 Here's the essential AHDL code: test_reg[].d = B"11"; test_reg[].clk = pld_clk; test_reg[].prn = !(!poreset/ & TEST_CONSTANT); test_reg[].clrn = !(!poreset/ & !TEST_CONSTANT); pld_clk is running at 66.66 MHz, TEST_CONSTANT = B"10", and test_reg[] is a two bit DFF. On the FPGA it runs as I expect: -When poreset/ = VCC --> test_reg[] = B"11" -When poreset/ = GND --> test_reg[] = B"10" But in ModelSim: -When poreset/ = VCC --> test_reg[] = B"U1" -When poreset/ = GND --> test_reg[] = B"U0"what is wrong with modelsim? I can't trust ModelSim for testing any more of my code. Also, I get these messages in ModelSim after attempting to run the simulation, but then it seems to run fine (after it runs though a bunch of code). # ** Error: (vsim-3601) Iteration limit reached at time 0 ns.# steptrack::findloop2... # Starting tryFindLoop at time 0 ns and delta 99999 . # steptrack::findloop3... # Starting tryFindLoop at time 0 ns and delta 100001 . # Next activity is in 1 ns.# Next activity is in 14 ns.# Stopping as time has advanced to 1 ns !! # Could not find any active process to start the loop analysis.
