11 years agoModelsim Fatal error: "TOO MANY PORT CONNECTONS" Help me!
Hi guys:
I tried to load a testbench in Modelsim after successful compilation in Quartus and Modelsim. But it encountered a fatal error: "** Fatal: (vsim-3365) /home/yumeng/Desktop/proc_testbench.v(33): Too many port connections. Expected 9, found 20." It seems that the ports of module System are mismatched but I think it works well. Code of the System module:
/* Altered System module for testbench. */
module System(DIN, Reset, PB, clock, WR_MEM_out, ADDR_out, DOUT_out, DONE, IR_out, R0_out, R1_out, R2_out, R3_out, R4_out, R5_out, R6_out, R7_out, A_out, G_out, CW);
input DIN;
input Reset;
input PB;
input clock;
output wire WR_MEM_out;
output wire DOUT_out;
output wire ADDR_out;
output wire DONE;
output wire IR_out;
output wire R0_out;
output wire R1_out;
output wire R2_out;
output wire R3_out;
output wire R4_out;
output wire R5_out;
output wire R6_out;
output wire R7_out;
output wire G_out;
output wire A_out;
//Control Wires
output wire CW;
wire gnz;
wire BusWires;
//Enables
wire R0_en, R1_en, R2_en, R3_en, R4_en, R5_en, R6_en, R7_en, A_en, G_en, IR_en;
wire ADD_SUB, COUNT_en, ADDR_en, DOUT_en, WR_MEM_en;
wire Mux_sel;
assign Mux_sel = CW;
assign R0_en = CW;
assign R1_en = CW;
assign R2_en = CW;
assign R3_en = CW;
assign R4_en = CW;
assign R5_en = CW;
assign R6_en = CW;
assign R7_en = CW;
assign A_en = CW;
assign G_en = CW;
assign IR_en = CW;
assign ADD_SUB = CW;
assign COUNT_en = CW;
assign ADDR_en = CW;
assign DOUT_en = CW;
assign WR_MEM_en = CW;
//Data not defined in output
wire ADD_SUB_out;
wire X_REG;
wire Y_REG;
//Instantiate Registers
registers R0(Reset, R0_en, clock, BusWires, R0_out);
registers R1(Reset, R1_en, clock, BusWires, R1_out);
registers R2(Reset, R2_en, clock, BusWires, R2_out);
registers R3(Reset, R3_en, clock, BusWires, R3_out);
registers R4(Reset, R4_en, clock, BusWires, R4_out);
registers R5(Reset, R5_en, clock, BusWires, R5_out);
registers R6(Reset, R6_en, clock, BusWires, R6_out);
registers_count R7(Reset, R7_en, COUNT_en, clock, BusWires, R7_out);
registers A(Reset, A_en, clock, BusWires, A_out);
register_g G(Reset, G_en, clock, ADD_SUB_out, G_out, gnz);
registers IR(Reset, IR_en, clock, DIN, IR_out);
registers ADDR(Reset, ADDR_en, clock, BusWires, ADDR_out);
registers DOUT(Reset, DOUT_en, clock, BusWires, DOUT_out);
flip_flop WR_MEM(Reset, clock, WR_MEM_en, WR_MEM_out);
add_sub stuff(A_out, BusWires, ADD_SUB, ADD_SUB_out);
data_mux mux(Mux_sel, R0_out, R1_out, R2_out, R3_out, R4_out, R5_out, R6_out, R7_out, DIN, G_out, BusWires);
three_to_8_decoder x_decoder(IR_out,X_REG);
three_to_8_decoder y_decoder(IR_out,Y_REG);
control M1(IR_out, X_REG, Y_REG, PB, Reset, clock, gnz, CW, DONE);
endmodule
Code for part of the testbench:
`timescale 1 ps / 1 ps
module proc_testbench;
wire PB; /* Run */
wire Reset;
wire enable; /* a generic write enable */
wire wren;
wire leden;
wire done;
wire clock;
wire mem_out;
wire address;
wire dout;
wire IR;
wire REG0;
wire REG1;
wire REG2;
wire REG3;
wire REG4;
wire REG5;
wire REG6;
wire PC; /* Register 7 */
wire AR;
wire GR;
wire led_out; /* LED output */
wire control;
assign wren = (~address && ~address && ~address && ~address)?(enable):0;
assign leden = (~address && ~address && ~address && ~address)?0:(enable);
proc_gen StimulusGenerator (PB, Reset, clock);
System DUV_1 (mem_out, Reset, PB, clock, enable, address, dout, done, IR, REG0, REG1, REG2, REG3, REG4, REG5, REG6, PC, AR, GR, control);
irram DUV_2 (address, clock, dout, wren, mem_out);
register_LED DUV_3 (Reset, leden, clock, dout, led_out);
proc_check Checker (mem_out, Reset, PB, enable, wren, leden, done, clock, address, dout, control, done, IR, REG0, REG1, REG2, REG3, REG4, REG5, REG6, PC, AR, GR, led_out);
endmodule
I think the 20 port connections are matched properly. Could anyone figure out what is the problem? Thanks in advance! Yumeng
