11 years agoI made a simple testcase from the code shown and cannot reproduce your error. I was not correct about the illegal syntax.
Since I don't have your complete design, I can't say for sure that this is your problem. I would try commenting out all other code until you are left with just the code producing the error. Basically, comment out all other module instantiations. The Verilog-2001 ANSI style port style I mentioned earlier is Verilog, no need for *.sv file extensions. The Verilog-1995 non-ANSI style normally looks likemodule name(port1,port2);
input port1;
output port2;
wire port1;
reg port2;
endmoduleNon-Ansi ports are declared at least twice, sometimes three times: the port name ordering, port direction, and port type. Your syntax has combined the port direction and port type. Verilog-2001 ANSI style port combine all three declarations into one declaration. module name(
input port1,
output reg port2
endmodule
