modelsim erro Unresolved defparam reference to 'dcfifo_component'
I'm back with FPGAs and I'm trying to simulate a simple FIFO from the standard IP catalogue for an Arria 10: 10AX115S3F45E2SG. Because my job is a little part of a big project I have write down a code without pins specification, because for now I only want RTL simulation. I have tested the test bench with my logic and it works, I can simulate it with modelsim but when I put the FIFO Modelsim complains, I attach the transcript at the end of the post. I checked all the files that modelsim complains and are all there in the folder specified. for information my configuration is: Ubutnu-Mate 16.04 Quartus Prime 18.0 (with license) Modelsim INTEL FPGA STARTER EDITION 10.5b thanks for the help, Guillermo# vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L twentynm_ver -L twentynm_hssi_ver -L twentynm_hip_ver -L twentynm -L twentynm_hssi -L twentynm_hip -L rtl_work -L work -L inputBuff2Clks_fifo_180 -voptargs="+acc" Compactor_tb# vsim -t 1ps -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L twentynm_ver -L twentynm_hssi_ver -L twentynm_hip_ver -L twentynm -L twentynm_hssi -L twentynm_hip -L rtl_work -L work -L inputBuff2Clks_fifo_180 -voptargs=""+acc"" Compactor_tb # Start time: 19:02:24 on Jun 28,2018# Loading std.standard# Loading std.textio(body)# Loading ieee.std_logic_1164(body)# Loading ieee.std_logic_textio(body)# Loading work.compactor_tb(beha)# Loading work.ut_compactor(beh)# Loading work.ut_compactor_basic(beh)# Loading ieee.numeric_std(body)# Loading verilog.vl_types(body)# Loading work.inputbuff2clks(rtl)# Loading inputBuff2Clks_fifo_180.inputBuff2Clks_fifo_180_czaw2fq# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(69): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.enable_ecc.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(70): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.intended_device_family.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(71): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.lpm_hint.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(72): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.lpm_numwords.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(73): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.lpm_showahead.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(74): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.lpm_type.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(75): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.lpm_width.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(76): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.lpm_widthu.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(77): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.overflow_checking.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(78): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.rdsync_delaypipe.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(79): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.read_aclr_synch.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(80): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.underflow_checking.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(81): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.use_eab.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(82): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.write_aclr_synch.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# ** Error (suppressible): (vsim-10000) /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v(83): Unresolved defparam reference to 'dcfifo_component' in dcfifo_component.wrsync_delaypipe.# Time: 0 ps Iteration: 0 Instance: /compactor_tb/CompactorDUT/CompBasic/inBuffClkDomain/fifo_0 File: /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/sim/inputBuff2Clks_fifo_180_czaw2fq.v# Loading work.elinkfromfile(beha)# Error loading design# Error: Error loading design# Pausing macro execution# MACRO ./compactorV01_run_msim_rtl_vhdl.do PAUSED at line 27
--- Quote Start --- I have tested the test bench with my logic and it works, I can simulate it with modelsim but when I put the FIFO Modelsim complains, I attach the transcript at the end of the post. --- Quote End --- Without code it is difficult to support, can you share your part of the code (after adding the FIFO & test bench)? Since it was worked before adding FIFO, It might have an issue while instantiating the “dcfifo_component”. Can you please refer the old thread & check any typo mistake, any missing port, signal declaration etc. https://www.alteraforum.com/forum/showthread.php?t=55761 Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation) - Altera_Forum
Have you generated the simulation models for the dcfifo that you created. If not, open the Qsys tool and generate the simulation models. Then include these simulation model sources also in your modelsim compilation flow. Now, it will find all of the required files and you will be able to simulate the design.
"Vikas Jathar " : here is the code, I thought it would be an error mostly related on libraries and Linux. I have searched for a typo in all the files generated by Quartus but I don't see nothing, but could be that I'm not recognizing the typo "eapenabrm": In quartus 18 there is no more Qsys tool, now it's called platform designer, that said, If open it I don't know what to do, i didn't use it to create the code. What I can says is that I've generated every thing from the IP catalog, all in vhdl. After answering this post I will try to do the same in verilogand I will post if there is any difference. The forum is warning me that the post is too long so I put test bench and top level on another reply, but I it will take a little because I have to extract from top_level and testbench the part dedicated to this.
CODE GENERATED BY QUARTUS IP CATALOG /home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/synth/inputBuff2Clks_pkg.vhdLIBRARY ieee; USE ieee.std_logic_1164.ALL; entity UT_Compactor_Basic is port( clkInStage : in std_logic; --Only these signals are synched to clkInStage nReset : in std_logic; elinkIn : in std_logic_vector(23 downto 0); data_valid_in : in std_logic; clkOutStage : in std_logic; --Everything else is synched to that CLK. data_out : out std_logic_vector(31 downto 0) ); END entity; architecture beh of UT_Compactor_Basic is component InputClockDomainSync is port ( CLKIn : in std_logic; --Only these signals are synched to clkInStage nReset : in std_logic; DataIn : in std_logic_vector(23 downto 0); DataValidIn : in std_logic; CLKOut : in std_logic; --Everything else is synched to that CLK. DataOut : out std_logic_vector(23 downto 0); DataValidOut : out std_logic ); end component InputClockDomainSync; component inputBuff2Clks is port ( data : in std_logic_vector(23 downto 0); -- fifo_input.datain wrreq : in std_logic; -- .wrreq rdreq : in std_logic; -- .rdreq wrclk : in std_logic; -- .wrclk rdclk : in std_logic; -- .rdclk aclr : in std_logic; -- .aclr q : out std_logic_vector(23 downto 0); -- fifo_output.dataout rdempty : out std_logic; -- .rdempty wrfull : out std_logic -- .wrfull ); end component inputBuff2Clks; signal newHeader : std_logic_vector(19 downto 0); signal newNumHits : std_logic_vector(5 downto 0); signal dataIn250 : std_logic_vector(23 downto 0); signal dataInValid250 : std_logic; signal wrfull,rdempty : std_logic; begin data_out <= "00000000" & dataIn250; inBuffClkDomain : inputBuff2Clks port map ( data => elinkIn, -- fifo_input.datain wrreq => data_valid_in, -- .wrreq rdreq => '1', -- .rdreq wrclk => clkInStage, -- .wrclk rdclk => clkOutStage, -- .rdclk aclr => '0', -- .aclr q => dataIn250, -- fifo_output.dataout rdempty => rdempty, -- .rdempty wrfull => wrfull -- .wrfull ); end beh;
/home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/synth/inputBuff2Clks.vhdlibrary IEEE; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; package inputBuff2Clks_pkg is component inputBuff2Clks_fifo_180_czaw2fq is port ( data : in std_logic_vector(23 downto 0) := (others => 'X'); -- datain wrreq : in std_logic := 'X'; -- wrreq rdreq : in std_logic := 'X'; -- rdreq wrclk : in std_logic := 'X'; -- wrclk rdclk : in std_logic := 'X'; -- rdclk aclr : in std_logic := 'X'; -- aclr q : out std_logic_vector(23 downto 0); -- dataout rdempty : out std_logic; -- rdempty wrfull : out std_logic -- wrfull ); end component inputBuff2Clks_fifo_180_czaw2fq; end inputBuff2Clks_pkg;
/home/guille/LHCb/UT/Tell40Dev/compactor_v1/HwSrc/inputBuff2Clks/fifo_180/synth/inputBuff2Clks_fifo_180_czaw2fq.v-- inputBuff2Clks.vhd -- Generated using ACDS version 18.0 614 library IEEE; library inputBuff2Clks_fifo_180; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; use inputBuff2Clks_fifo_180.inputBuff2Clks_pkg.all; entity inputBuff2Clks is port ( data : in std_logic_vector(23 downto 0) := (others => '0'); -- fifo_input.datain wrreq : in std_logic := '0'; -- .wrreq rdreq : in std_logic := '0'; -- .rdreq wrclk : in std_logic := '0'; -- .wrclk rdclk : in std_logic := '0'; -- .rdclk aclr : in std_logic := '0'; -- .aclr q : out std_logic_vector(23 downto 0); -- fifo_output.dataout rdempty : out std_logic; -- .rdempty wrfull : out std_logic -- .wrfull ); end entity inputBuff2Clks; architecture rtl of inputBuff2Clks is begin fifo_0 : component inputBuff2Clks_fifo_180.inputBuff2Clks_pkg.inputBuff2Clks_fifo_180_czaw2fq port map ( data => data, -- fifo_input.datain wrreq => wrreq, -- .wrreq rdreq => rdreq, -- .rdreq wrclk => wrclk, -- .wrclk rdclk => rdclk, -- .rdclk aclr => aclr, -- .aclr q => q, -- fifo_output.dataout rdempty => rdempty, -- .rdempty wrfull => wrfull -- .wrfull ); end architecture rtl; -- of inputBuff2Clks// synopsys translate_off `timescale 1 ps / 1 ps // synopsys translate_on module inputBuff2Clks_fifo_180_czaw2fq ( aclr, data, rdclk, rdreq, wrclk, wrreq, q, rdempty, wrfull); input aclr; input data; input rdclk; input rdreq; input wrclk; input wrreq; output q; output rdempty; output wrfull; `ifndef ALTERA_RESERVED_QIS // synopsys translate_off `endif tri0 aclr; `ifndef ALTERA_RESERVED_QIS // synopsys translate_on `endif wire sub_wire0; wire sub_wire1; wire sub_wire2; wire q = sub_wire0; wire rdempty = sub_wire1; wire wrfull = sub_wire2; dcfifo dcfifo_component ( .aclr (aclr), .data (data), .rdclk (rdclk), .rdreq (rdreq), .wrclk (wrclk), .wrreq (wrreq), .q (sub_wire0), .rdempty (sub_wire1), .wrfull (sub_wire2), .eccstatus (), .rdfull (), .rdusedw (), .wrempty (), .wrusedw ()); defparam dcfifo_component.enable_ecc = "FALSE", dcfifo_component.intended_device_family = "Arria 10", dcfifo_component.lpm_hint = "DISABLE_DCFIFO_EMBEDDED_TIMING_CONSTRAINT=TRUE", dcfifo_component.lpm_numwords = 4, dcfifo_component.lpm_showahead = "OFF", dcfifo_component.lpm_type = "dcfifo", dcfifo_component.lpm_width = 24, dcfifo_component.lpm_widthu = 2, dcfifo_component.overflow_checking = "ON", dcfifo_component.rdsync_delaypipe = 5, dcfifo_component.read_aclr_synch = "OFF", dcfifo_component.underflow_checking = "ON", dcfifo_component.use_eab = "ON", dcfifo_component.write_aclr_synch = "OFF", dcfifo_component.wrsync_delaypipe = 5; endmodule - Altera_Forum
Try to add -L altera_mf_ver to command-line options, before -L altera_mf.
eugenek, where I have to put this line?
Also, could this be a problem with licenses? - Altera_Forum
Ok, after fighting with no succes, I moved to Quartus 18 pro in windows, WTF did intel or altera with the easy simulation?!?!? it was a one button click!! and now is a horrible scripting way, anyway...
I don't "close" this post. I would like to know if it's possible to do simulation of Arria10 with Quartus Prime Standard Edition - Altera_Forum
“check your notifications”
I could able to replicate your issue & it seems to be a bug in NativeLink (.do file). We will come back soon. Best Regards Vikas Jathar (This message was posted on behalf of Intel Corporation) - Altera_Forum
Ok, Thanks.
I will be checking for news - Ftiglius
HI! I meet same error simulating a dcfifo 16 bit to 8 bit, 32 words deep.
I insert suggested option -L altera_mf_ver on .do file that Modelsim reads to launch simulation, but it doesnt' work. Same errors!
There is any workaround to simulate it ?? (Quartus prime 18.0, Modelsim INTEL FPGA STARTER EDITION 10.5b..
Thanks for any suggestion!
