8 years agomodelsim erro Unresolved defparam reference to 'dcfifo_component'
Hi, I'm back with FPGAs and I'm trying to simulate a simple FIFO from the standard IP catalogue for an Arria 10: 10AX115S3F45E2SG. Because my job is a little part of a big project I have wri...
8 years agoHave you generated the simulation models for the dcfifo that you created. If not, open the Qsys tool and generate the simulation models. Then include these simulation model sources also in your modelsim compilation flow. Now, it will find all of the required files and you will be able to simulate the design.
