16 years ago
Modelsim-Altera errors
My design incorporates a PLL that I phase shift to be 180 degrees off-phase to another clock with the same frequency. The phase shift is done by a pll_reconfig block.
When I run gate level simulation in modelsim-altera it seems to work just fine but suddenly after a while the signals turn red and I receive the following error:
# ** Error: C:/altera/91/modelsim_ase/win32aloem/../altera/verilog/src/stratixii_atoms.v(1655): $hold( posedge clk &&& nosloadsclr:3614784 ps, datain:3614950 ps, 200 ps );# Time: 3614950 ps Iteration: 0 Instance: /tb_top/top_i/\ch0_i|clk_optimizer_i|phase_shift # ** Error: C:/altera/91/modelsim_ase/win32aloem/../altera/verilog/src/stratixii_atoms.v(1655): $hold( posedge clk &&& nosloadsclr:3614784 ps, datain:3614954 ps, 200 ps );# Time: 3614954 ps Iteration: 0 Instance: /tb_top/top_i/\ch0_i|clk_optimizer_i|fsm_state.STATE_DONE # ** Error: C:/altera/91/modelsim_ase/win32aloem/../altera/verilog/src/stratixii_atoms.v(1655): $hold( posedge clk &&& nosloadsclr:3614784 ps, datain:3614958 ps, 200 ps );# Time: 3614958 ps Iteration: 0 Instance: /tb_top/top_i/\ch0_i|clk_optimizer_i|fsm_state.STATE_ADJUST # ** Error: C:/altera/91/modelsim_ase/win32aloem/../altera/verilog/src/stratixii_atoms.v(1655): $hold( posedge clk &&& nosloadsclr:3630889 ps, datain:3630907 ps, 200 ps );# Time: 3630907 ps Iteration: 0 Instance: /tb_top/top_i/\ch1_i|clk_optimizer_i|fsm_state.STATE_ADJUST # ** Error: C:/altera/91/modelsim_ase/win32aloem/../altera/verilog/src/stratixii_atoms.v(1655): $hold( posedge clk &&& nosloadsclr:3630889 ps, datain:3630918 ps, 200 ps );# Time: 3630918 ps Iteration: 0 Instance: /tb_top/top_i/\ch1_i|clk_optimizer_i|fsm_state.STATE_DONE # ** Error: C:/altera/91/modelsim_ase/win32aloem/../altera/verilog/src/stratixii_atoms.v(1655): $hold( posedge clk &&& nosloadsclr:3630889 ps, datain:3630918 ps, 200 ps );# Time: 3630918 ps Iteration: 0 Instance: /tb_top/top_i/\ch1_i|clk_optimizer_i|phase_shift
The errors aren't very intuitive as to their meaning, anyone who knows what they mean?
    The module that does the re-programming of the pll looks like this, and it's the parameters in this module that the errors refer to.
    module clk_optimizer(
      // System reset
      input reset_n,
      // Tx clock, not phase adjustable
      input tx_clk,
      // Rx clock, phase adjustable
      input rx_clk,
      // PLL reconfiguration I/F
      input  busy,
      input  locked,
      output reg phase_shift,
      output reg direction,
      // Status/Control
      input  realign,
      output reg done);
      // FSM states
      parameter
        STATE_DECIDE = 2'h0,
        STATE_ADJUST = 2'h1,
        STATE_DONE   = 2'h2,
        STATE_DUMMY3 = 2'h3;
      reg  fsm_state;
      always @(posedge tx_clk, negedge reset_n) begin
        if (!reset_n) begin
          fsm_state   <= STATE_DECIDE;
          done        <= 0;
          phase_shift <= 0;
          direction   <= 0;
        end else begin
          // FSM
          case (fsm_state)
            STATE_DECIDE: begin
              if (locked && !busy) begin
                fsm_state <= STATE_ADJUST;
                direction <= !rx_clk; // rx_clk would phase-align
              end
            end
            STATE_ADJUST: begin
              if (locked && !busy && !phase_shift) begin
                if (rx_clk == !direction) begin // Still too early/late
                  phase_shift <= 1;
                end else begin
                  fsm_state <= STATE_DONE;
                end
              end else begin
                phase_shift <= 0;
              end
            end
            STATE_DONE: begin
                if (realign) begin
                  done <= 0;
                end else begin
                  done <= 1;
                end
              end
            end
            default: begin
            end
          endcase
        end
      end
    endmodule
    --- Quote Start ---
      // System reset
      input reset_n,
      input tx_clk,
      input rx_clk,
      input  busy,
      input  locked,
      // Status/Control
      input  realign,
      output reg done);
      // FSM states
      parameter
        STATE_DONE   = 2'h2,
      reg  fsm_state;
        if (!reset_n) begin
          done        <= 0;
          phase_shift <= 0;
          direction   <= 0;
        end else begin
          // FSM
          case (fsm_state)
            STATE_DECIDE: begin
              end
            end
            STATE_ADJUST: begin
                  phase_shift <= 1;
                end else begin
                end
              end else begin
                phase_shift <= 0;
              end
            end
            STATE_DONE: begin
                if (realign) begin
                  done <= 0;
                end else begin
                  done <= 1;
                end
              end
            end
            default: begin
            end
          endcase
        end
      end
    endmodule
    --- Quote End ---
    for me it looks like that you have timing violations in your design. Did you run a timing analysis in Quartus ?
    Kind regards
    GPK
    Thanks for your reply, I do have timing violations it seems. Are these types of error messages a normal indication of timing violations?
    --- Quote Start ---
    --- Quote End ---
    yes, in a simulator you will get such or similar messages for timing violations.
    This messages indicates that you have a holdtime violation.
    Your Clock edge occurs at simulation time 3614784 ps
    Your data changed at 3614950 ps, that is 166ps behind the clockedge. Require are 200ps.
    You have a time violation of 34ps.
    Is this a path in your design ?
    Kind regards
    GPK
    Well this is actually a desired behavior. I have two clocks in this block tx_clk and rx_clk and I sample rx_clk on rising edge of tx_clk and phase shift rx_clk until it changes value. This (theoretically at least) gives me a 180 degrees phase difference between the two which is exactly what I want.
    How would I go about setting a constraint that tells quartus that this is ok?
    --- Quote Start ---
    --- Quote End ---
    maybe I missed something, but why couldn't you use the inverted tx_clk?
    Kind regards
    GPK
    RX_CLOCK REGION
    ===[10 Gbit/s serial optical data]===> Opto-demux ===[16bit@622MHz]===> FPGA-LVDS_RX, PLL ===[128bit@77MHz]===>
    TX_CLOCK REGION
    mirror of above except that the transmission clock (622 MHz) is fed from the same opto-mux circuit. This is used in a Fast PLL in the FPGA to have another 77 MHz clock.
    The two 77 MHz clocks are the ones referred to above, once the PLLs have locked they will have the exact same frequency but unknown phase shift between each other. This is to make sure that the transmission of data between the two internal clock regions won't cause issues due to the clock edges being too close.
    --- Quote Start ---
    RX_CLOCK REGION
    TX_CLOCK REGION
    --- Quote End ---
    if the 77MHz clocks have exactly the same frequency and only a phase shift of 180 degrees is required, you can invert your rx_clk. If you do this Quartus will take care about the timing.
    Kind regards
    GPK
