--- Quote Start ---
The module that does the re-programming of the pll looks like this, and it's the parameters in this module that the errors refer to.
module clk_optimizer(
// System reset
input reset_n,
// Tx clock, not phase adjustable
input tx_clk,
// Rx clock, phase adjustable
input rx_clk,
// PLL reconfiguration I/F
input busy,
input locked,
output reg phase_shift,
output reg direction,
// Status/Control
input realign,
output reg done);
// FSM states
parameter
STATE_DECIDE = 2'h0,
STATE_ADJUST = 2'h1,
STATE_DONE = 2'h2,
STATE_DUMMY3 = 2'h3;
reg fsm_state;
always @(posedge tx_clk, negedge reset_n) begin
if (!reset_n) begin
fsm_state <= STATE_DECIDE;
done <= 0;
phase_shift <= 0;
direction <= 0;
end else begin
// FSM
case (fsm_state)
STATE_DECIDE: begin
if (locked && !busy) begin
fsm_state <= STATE_ADJUST;
direction <= !rx_clk; // rx_clk would phase-align
end
end
STATE_ADJUST: begin
if (locked && !busy && !phase_shift) begin
if (rx_clk == !direction) begin // Still too early/late
phase_shift <= 1;
end else begin
fsm_state <= STATE_DONE;
end
end else begin
phase_shift <= 0;
end
end
STATE_DONE: begin
if (realign) begin
done <= 0;
end else begin
done <= 1;
end
end
end
default: begin
end
endcase
end
end
endmodule
--- Quote End ---
for me it looks like that you have timing violations in your design. Did you run a timing analysis in Quartus ?
Kind regards
GPK
