14 years ago
ModelSim -> Error: xxxxx.vhd(n): Library yyyy not found
I'm trying to run an RTL Simulation of a project using the NativeLink set-up in Quartus II. But I end up with the following error: (in red)
--- Quote Start ---
Reading C:/altera/11.0sp1/modelsim_ase/tcl/vsim/pref.tcl
# do GrabReader_run_msim_rtl_vhdl.do
# if {[file exists rtl_work]} {
# vdel -lib rtl_work -all
# vlib rtl_work
# vmap work rtl_work
# Copying c:\altera\11.0sp1\modelsim_ase\win32aloem/../modelsim.ini to modelsim.ini
# Modifying modelsim.ini
# ** Warning: Copied c:\altera\11.0sp1\modelsim_ase\win32aloem/../modelsim.ini to modelsim.ini.
# Updated modelsim.ini.
# vcom -93 -work work {C:/qdesigns/c-cam/bb/vhdl_packages/CC_Data_Types.vhd}
# Model Technology ModelSim ALTERA vcom 6.6d Compiler 2010.11 Nov 2 2010
# -- Loading package standard
# -- Loading package std_logic_1164
# -- Loading package numeric_std
# -- Loading package math_real
# -- Loading package lpm_components
# -- Compiling package cc_data_types
# -- Compiling package body cc_data_types
# -- Loading package cc_data_types
# vcom -93 -work work {C:/qdesigns/c-cam/bb/gates/regmux/regmux.vhd}
# ** Error: C:/qdesigns/c-cam/bb/gates/regmux/regmux.vhd(7): Library cc_data_types not found.
# ** Error: C:/qdesigns/c-cam/bb/gates/regmux/regmux.vhd(8): (vcom-1136) Unknown identifier "cc_data_types".
# ** Error: C:/qdesigns/c-cam/bb/gates/regmux/regmux.vhd(11): VHDL Compiler exiting
# ** Error: c:/altera/11.0sp1/modelsim_ase/win32aloem/vcom failed.
# Error in macro ./GrabReader_run_msim_rtl_vhdl.do line 9
# c:/altera/11.0sp1/modelsim_ase/win32aloem/vcom failed.
# while executing
# "vcom -93 -work work {C:/qdesigns/c-cam/bb/gates/regmux/regmux.vhd}"
--- Quote End ---
So Modelsim doesn't seem to find a package in a lower module, although it had no problem locating it just a bit earlier.
If I run the Gate Level Simulation everything runs OK, except that I don't get a clock running.
	genclk : process
		begin
			Clk <= '0' ;
			wait for TClChClk ;
			Clk <= '1' ;
			wait for TClChClk ;
		end process genclk ;
For building Lower level modules a Gate Level Simulation is not really necessary, so I tried the RTL Simulaton.
Any clues?
