MAX10 LVDS Output Issue in one Single Differential Pair
We are using the MAX10M08SAE144I7G and have a problem with a specific LVDS output pin.
The signals A and C, which use pins 38, 39 and 57, 58, show correct LVDS signals on the oscilloscope. However, for signal B, using pins 44 and 45, we observe like two single-ended signals with the same phase instead of a proper LVDS signal. (Using 100 ohm termination)
All three differential pairs are from the same bank (bank 3 on bottom), which supports true LVDS output. Bank 3 is powered with 2.5V.
Even when we declare only signal B, it still doesn’t work.
We tested the same firmware on the MAX 10 10M08 Eval Kit Board, which uses the MAX10M08SAE144C8G FPGA, and signal B works correctly in true LVDS.
Albert E.
sounds to me like broken PCB trace or not correctly soldered pin.
Which signal B voltage are you seeing? Can't be normal LVDS voltage with differential termination.
- FvM
Which signal B voltage are you seeing? Can't be normal LVDS voltage with differential termination.- AlbertEspinya
Hi, one of the differential pins was not soldered properly. Thanks!
- AqidAyman_Altera
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
