AlbertEspinya
1 year agoMAX10 LVDS Output Issue in one Single Differential Pair
Hi, We are using the MAX10M08SAE144I7G and have a problem with a specific LVDS output pin. The signals A and C, which use pins 38, 39 and 57, 58, show correct LVDS signals on the oscilloscope. Howe...
- 1 year ago
sounds to me like broken PCB trace or not correctly soldered pin.
Which signal B voltage are you seeing? Can't be normal LVDS voltage with differential termination.
FvM
1 year agoHi,
AlbertEspinya
1 year agoHi, one of the differential pins was not soldered properly. Thanks!
