Pooja_03's avatar
Pooja_03
1 year ago
MAX10 (10M50DAF484C8G): Maximum Frequency for CLK In, CLK Out, and GPIO Pins"
I am working with the MAX10 FPGA (part number: 10M50DAF484C8G) and would like to know the maximum frequency that can be used for the following:
  1. CLK In
  2. CLK Out
  3. Normal GPIO pins
Could you provide details on the highest possible frequency for these signals with this specific part?
Thank you for your assistance!"
Pooja Sharma
  • Pooja_03's avatar
    Pooja_03
    Can the maximum frequency of pll_clk_out be 100 MHz? Is it possible to output a 100 MHz from it? Similarly, can we drive the GPIO pins with a 100 MHz signal?
    Thank you
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    Based on the MAX 10 datasheet for PLL specifications, PLL output frequency for external clock output can go up to 472.5 MHz. However, this parameter is limited in the Intel® Quartus® Prime software by the I/O maximum frequency. The maximum I/O frequency is different for each I/O standard.
    Aqid
    AqidAyman_Altera
    I wish to follow up, do you need more support on this?
    Aqid
  • Pooja_03's avatar
    Pooja_03
    Hi Aqid,
    Can you please tell the maximum frequency for 1.8-V LVCMOS I/O standard?
    Thank you
    AqidAyman_Altera
    You must perform timing closure analysis to determine the maximum achievable frequency for general purpose I/O standards.
    Just so you know, actual achievable frequency depends on design and system-specific factors. Ensure proper timing closure in your design and perform HSPICE/IBIS simulations based on your specific design and system setup to determine the maximum achievable frequency in your system.
    Link for IBIS Model:
    https://www.intel.com/content/www/us/en/support/programmable/support-resources/board-layout/ibs-ibis-index.html
    Aqid
    AqidAyman_Altera
    I wish to follow up with you.
    Do you have any more concerns on this question before I close this thread?
    • Pooja_03's avatar
      Pooja_03
      Hi Aqid,
      Thank you for response.
      Yes, you may close this thread.
      Thank you
    AqidAyman_Altera
    I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
