Yes, after deleting the directory, and compiling again it works on MatLab 2010.
In MatLab 2009a after compiling the .mdl with Signal Compiler (Device EP3... instead of EP4...) I want to compile it in a HiL-Block and get an error
Info: Running Quartus II 32-bit Analysis & Synthesis
Info: Version 11.1 Build 259 01/25/2012 Service Pack 2 SJ Full Version
Info: Processing started: Wed Mar 14 13:18:10 2012
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off clk_test -c clk_test_HIL
Info (20029): Only one processor detected - disabling parallel compilation
Info (12021): Found 2 design units, including 2 entities, in source file /01_bachelorarbeit_romanowski/02_matlab/94_chm_fxpt_mmvr/fxpt_mmvr/clk_test.mdl
Info (12023): Found entity 1: clk_test
Info (12023): Found entity 2: clk_test_Interface
Warning (12019): Can't analyze file -- file ../../../../../Dokumente und Einstellungen/chm/eigene dateien/Studienarbeit/matlab/fxpt_mmvr/ckdiv.v is missing
Warning (12019): Can't analyze file -- file ../../../../../Dokumente und Einstellungen/chm/eigene dateien/Studienarbeit/matlab/fxpt_mmvr/cnt.v is missing
Warning (12019): Can't analyze file -- file ../../../../../Dokumente und Einstellungen/chm/eigene dateien/Studienarbeit/matlab/fxpt_mmvr/LEDmeter.v is missing
Warning (12019): Can't analyze file -- file ../../../../../Dokumente und Einstellungen/chm/eigene dateien/Studienarbeit/matlab/fxpt_mmvr/SEG7_LUT.v is missing
Info (12021): Found 6 design units, including 6 entities, in source file /01_bachelorarbeit_romanowski/02_matlab/94_chm_fxpt_mmvr/fxpt_mmvr/ckdiv.v
Info (12023): Found entity 1: ckdiv_25m_dc50
Info (12023): Found entity 2: ckdiv_50m_dc50
Info (12023): Found entity 3: ckdiv_pfrq_dc50
Info (12023): Found entity 4: ckdiv_ifrq_dc50
Info (12023): Found entity 5: ckdiv_ifrq_pw1
Info (12023): Found entity 6: ckdiv_50m_dc50_cnt
Info (12021): Found 1 design units, including 1 entities, in source file /01_bachelorarbeit_romanowski/02_matlab/94_chm_fxpt_mmvr/fxpt_mmvr/cnt.v
Info (12023): Found entity 1: cnt16r
Info (12021): Found 5 design units, including 5 entities, in source file /01_bachelorarbeit_romanowski/02_matlab/94_chm_fxpt_mmvr/fxpt_mmvr/ledmeter.v
Info (12023): Found entity 1: LedMeterLin8
Info (12023): Found entity 2: LedMeterLin16
Info (12023): Found entity 3: LedMeterLog8
Info (12023): Found entity 4: LedMeterLog16
Info (12023): Found entity 5: LedMeterLog18
Info (12021): Found 2 design units, including 2 entities, in source file /01_bachelorarbeit_romanowski/02_matlab/94_chm_fxpt_mmvr/fxpt_mmvr/seg7_lut.v
Info (12023): Found entity 1: SEG7_LUT
Info (12023): Found entity 2: SEG7_LUT_EXTENDED
Info (12021): Found 1 design units, including 1 entities, in source file /altera/11.1/quartus/dsp_builder/lib/hilaltr_node.v
Info (12023): Found entity 1: hilaltr_node
Warning (10275): Verilog HDL Module Instantiation warning at clk_test_HIL.v(117): ignored dangling comma in List of Port Connections
Info (12021): Found 1 design units, including 1 entities, in source file clk_test_hil.v
Info (12023): Found entity 1: clk_test_HIL
Info (12127): Elaborating entity "clk_test_HIL" for the top level hierarchy
Error (10130): Verilog HDL error at clk_test_HIL.v(38): parameter "N_NODE_IR_BITS" is not a formal parameter of instantiated module File: C:/01_Bachelorarbeit_Romanowski/02_MatLab/94_CHM_fxpt_mmvr/fxpt_mmvr/clk_test_dspbuilder/clk_test_HIL.v Line: 38
Error (12153): Can't elaborate top-level user hierarchy
