14 years agoDepends if the static class path contains a reference to DSP Builder.
If the static class path doesn't point to a DSP Builder jar file then the signal compiler window wouldn't even appear. The error message you're getting when using the Signal compiler seems to imply that you already have a qpf in the same directory as your mdl file. (It may be in the directory called <model>_dspbuilder).
