14 years agoMATLAB R2009a will almost certainly work with DSP Builder 11.1SP2. It's just that the installer won't detect older versions. You can get around this by entering the path to MATLAB manually on the MATLAB selection page.
Try loading the quartus project manually in Quartus II 11.1SP2 first and then resave it. This should allow DSP Builder to use it. It's possible your MATLAB installation has references to two different Quartus/DSP Builder versions. To check this, run the following commands:path
javaclasspath and check that there are only paths from one version.
