14 years agoIf you read back through my posts I explained that you could use MATLAB R2009a with DSP Builder 11.1 and I explained how you could do it.
--- Quote Start --- MATLAB R2009a will almost certainly work with DSP Builder 11.1SP2. It's just that the installer won't detect older versions. You can get around this by entering the path to MATLAB manually on the MATLAB selection page. --- Quote End --- All your previous errors were down to you having files generated by older versions of DSP Builder lying around. If you delete all these files and use the newer version of DSP Builder/Quartus exclusively you shouldn't have these problems.
