Logic generation failed to load result from design analysis and cannot get the list of IPs in design
- 2 years ago
Which OS are you running?
Could you check whether it is supported on the webpage below?
Perhaps you can update your system so that it aligns with your colleague's system.
At this point, it is hard for us to debug what's wrong, as we are not able to duplicate the issue.
Richard Tan
I do not see this error and able to pass the Analysis & Synthesis stage using Cyclone 10 GX.
What device are you using? What is the setting that you used when generate the example design? Perhaps a screenshot and an example design attachment will help me to debug further.
Also, could you check that you have the license activated for the JESD204B in the License Setup in Quartus. Or you can check in the license.dat file.
Similar forum case on JESD204B license: https://community.intel.com/t5/Programmable-Devices/Purchasing-IP-license-for-Intel-JESD204B-IP-core/m-p/1462547
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
Hi, thanks for the reply @RichardTanSY_Altera
Since you have asked for the device and settings, I'm explaining in detail.
I've tried to generate the example design for F-Tile JESD204B Intel FPGA IP, with existing preset mode(LMF=222) and tried compiling in Agilex 7 device (AGFB027R24C2E3VR2).
But during the run of Analysis & Synthesis stage, there comes error in the support logic generation stage flashing the error message like "Logic generation failed to load results from design analysis and cannot get the list of IPs in the design"
Also, I have the license activated for the JESD204B in the License Setup in Quartus.
I'm attaching the snaps for your reference here.
