Linux : Unexpected error code 89
Hi! (I'm using Centos 5)
I'm trying to download my hardware configuration in my board but when I run the programmer there's a message from Quartus that said that an error with code 89 occurs. What is this ? anyone knows what's going on? Thank for answer me.11 Replies
I have the same problem and the same OS (quartus and nios2 suite 9.1, Centos 5.4 64 bit).
Can anyone help us? - Altera_Forum
I downloaded quartus 9.1 for linux yesterday and got the same issue on RHEL 4. If you run:
quartus-pgm --auto from the command line you get much more information. It appears to be a problem with configuration of the usb jtag device. It looks like you need to set up a udev rule to handle the jtag device on usb. I haven't got to the bottom of it yet, so if anyone can help I would be glad to hear any suggestions. Thread 1207 (I'm not allowed to post a link to it apparently) seems to have all the correct information, but I haven't got my RHEL 4 udev sorted out, and I can't seem to get it to recognise the jtagd service. If I get it sorted soon I will post a reply here. - Altera_Forum
The likely cause of this error report is with Linux and how it grants permissions to the USB device. A further symptom of this problem is that you can successfully access the JTAG interface as root, but not as a non-root user.
The Quartus® II software uses the built-in USB drivers (usbfs) on your Linux distro to access the USB-Blaster download cable. By default, root is the only user allowed to use usbfs. You must change the permission on the ports before you can use the USB-Blaster download cable to program devices with the Quartus II software. Please review the USB Blaster User Guide: Go to page 13 of the USB-Blaster Download Cable User Guide on Altera.com altera.com/literature/ug/ug_usb_blstr.pdf#page=13 - Altera_Forum
hello
Please can u provide me with more details i couldn't solve this problem.I'm new to linux. i've CentOS 6.3 and quartus II 10.1 Thank u so much - Altera_Forum
For udev issues, you just need to create a rule; for this purpose, just copy and paste the following into a text editor (gedit for example) :
Pay attention to not add line brakes ! then , you save it as : 40-usbblaster.rules then copy (with root privileges) into : /etc/udev/rules.d After a reboot, it should work ... (I'm a debian user, it may be a bit different on another distribution, i should be able to help in such a case ! And i presume you are using a usbblaster or some kind of)SUBSYSTEM=="usb", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6001", GROUP="plugdev", MODE="0666", SYMLINK+="usbblaster" - Altera_Forum
Thanks a lot, I'm using quartus 13.0 on linuxmint 13 maya 64 bit and had the same problem with USB blaster (errror 89), and pasting the stuff from the official instructions didn't seem to work. This fixed it though.
--- Quote Start --- Hi, For udev issues, you just need to create a rule; for this purpose, just copy and paste the following into a text editor (gedit for example) :
Pay attention to not add line brakes ! then , you save it as : 40-usbblaster.rules then copy (with root privileges) into : /etc/udev/rules.d After a reboot, it should work ... (I'm a debian user, it may be a bit different on another distribution, i should be able to help in such a case ! And i presume you are using a usbblaster or some kind of) --- Quote End ---SUBSYSTEM=="usb", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6001", GROUP="plugdev", MODE="0666", SYMLINK+="usbblaster" - Altera_Forum
Happy it works for you !
Cheers - Altera_Forum
Pay attention to not add line brakes ! then , you save it as : 40-usbblaster.rules then copy (with root privileges) into : /etc/udev/rules.d After a reboot, it should work ... (I'm a debian user, it may be a bit different on another distribution, i should be able to help in such a case ! And i presume you are using a usbblaster or some kind of) --- Quote End --- Thank you very much . My problem sloved also.And I use the debian 7.3 quartus 11.0 in the kde desktop surroundings.SUBSYSTEM=="usb", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6001", GROUP="plugdev", MODE="0666", SYMLINK+="usbblaster" - Altera_Forum
Hi
The solution from lyrez did not work for me. I'm using (inside a VM with USB-Passthrough):
The following line inside a udev-rules-file "/etc/udev/50-embedded-devices.rules" did the trick though:Linux 3.10.30-1-MANJARO# 1 SMP Fri Feb 14 06:07:50 UTC 2014 x86_64 GNU/Linux and Quartus II 32-bit Version 13.1.0 Build 10/23/2013 SJ Web Edition
This should work for Arch Linux in general (Manjaro is a linux distribution based on Arch Linux). I used the following resource as starting point: https://wiki.archlinux.org/index.php/udev --- Quote Start --- Hi, For udev issues, you just need to create a rule; for this purpose, just copy and paste the following into a text editor (gedit for example) :SUBSYSTEM=="usb", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6001", GROUP="users", MODE="0666"
Pay attention to not add line brakes ! then , you save it as : 40-usbblaster.rules then copy (with root privileges) into : /etc/udev/rules.d After a reboot, it should work ... (I'm a debian user, it may be a bit different on another distribution, i should be able to help in such a case ! And i presume you are using a usbblaster or some kind of) --- Quote End ---SUBSYSTEM=="usb", ATTRS{idVendor}=="09fb", ATTRS{idProduct}=="6001", GROUP="plugdev", MODE="0666", SYMLINK+="usbblaster" - ADave
For the entire knowledge to get the full process of the quartus 13.0 on linuxmint 13 maya 64 bit and had the same problem with USB blaster (errror 89) that you can get easily from the help of the Google Drive tech help - https://googlesupport.co/google-drive-support/ to maintain the full process.
