17 years agoLinux : Unexpected error code 89
Hi! (I'm using Centos 5) I'm trying to download my hardware configuration in my board but when I run the programmer there's a message from Quartus that said that an error with code 89 occurs. W...
16 years agoThe likely cause of this error report is with Linux and how it grants permissions to the USB device. A further symptom of this problem is that you can successfully access the JTAG interface as root, but not as a non-root user.
The Quartus® II software uses the built-in USB drivers (usbfs) on your Linux distro to access the USB-Blaster download cable. By default, root is the only user allowed to use usbfs. You must change the permission on the ports before you can use the USB-Blaster download cable to program devices with the Quartus II software. Please review the USB Blaster User Guide: Go to page 13 of the USB-Blaster Download Cable User Guide on Altera.com altera.com/literature/ug/ug_usb_blstr.pdf#page=13
