11 years agoLED Breahing DE0 nano
can you help me what the meaning of this short program
it's from demos de0 nano i want to convert it to vhdl" pwm_width <= pwm_width[5:0]+ pwm_adj;
if(counter[26])
begin
pwm_adj <= counter[25:20];
end
else begin
pwm_adj <= ~ counter[25:20];
end " this the full demos program // ============================================================================ // Copyright (c) 2011 by Terasic Technologies Inc. // ============================================================================ // // Permission: // // Terasic grants permission to use and modify this code for use // in synthesis for all Terasic Development Boards and Altera Development // Kits made by Terasic. Other use of this code, including the selling // ,duplication, or modification of any portion is strictly prohibited. // // Disclaimer: // // This VHDL/Verilog or C/C++ source code is intended as a design reference // which illustrates how these types of functions can be implemented. // It is the user's responsibility to verify their design for // consistency and functionality through the use of formal // verification methods. Terasic provides no warranty regarding the use // or functionality of this code. // // ============================================================================ // // Terasic Technologies Inc // 356 Fu-Shin E. Rd Sec. 1. JhuBei City, // HsinChu County, Taiwan // 302 // // web: http://www.terasic.com/ // email: [email protected] // // ============================================================================ // Major Functions/Design Description: // // Please refer to DE0_Nano_User_manual.pdf in DE0_Nano system CD. // // ============================================================================ // Revision History: // ============================================================================ // Ver.: |Author: |Mod. Date: |Changes Made: // V1.0 |EricChen |02/01/2011 | // ============================================================================ //======================================================= // This code is generated by Terasic System Builder //======================================================= module DE0_NANO( //////////// CLOCK ////////// CLOCK_50, //////////// LED ////////// LED, //////////// KEY ////////// KEY, //////////// SW ////////// SW, //////////// SDRAM ////////// DRAM_ADDR, DRAM_BA, DRAM_CAS_N, DRAM_CKE, DRAM_CLK, DRAM_CS_N, DRAM_DQ, DRAM_DQM, DRAM_RAS_N, DRAM_WE_N, //////////// EPCS ////////// EPCS_ASDO, EPCS_DATA0, EPCS_DCLK, EPCS_NCSO, //////////// Accelerometer and EEPROM ////////// G_SENSOR_CS_N, G_SENSOR_INT, I2C_SCLK, I2C_SDAT, //////////// ADC ////////// ADC_CS_N, ADC_SADDR, ADC_SCLK, ADC_SDAT, //////////// 2x13 GPIO Header ////////// GPIO_2, GPIO_2_IN, //////////// GPIO_0, GPIO_0 connect to GPIO Default ////////// GPIO_0_D, GPIO_0_IN, //////////// GPIO_0, GPIO_1 connect to GPIO Default ////////// GPIO_1_D, GPIO_1_IN, ); //======================================================= // PARAMETER declarations //======================================================= //======================================================= // PORT declarations //======================================================= //////////// CLOCK ////////// input CLOCK_50; //////////// LED ////////// output [7:0] LED; //////////// KEY ////////// input [1:0] KEY; //////////// SW ////////// input [3:0] SW; //////////// SDRAM ////////// output [12:0] DRAM_ADDR; output [1:0] DRAM_BA; output DRAM_CAS_N; output DRAM_CKE; output DRAM_CLK; output DRAM_CS_N; inout [15:0] DRAM_DQ; output [1:0] DRAM_DQM; output DRAM_RAS_N; output DRAM_WE_N; //////////// EPCS ////////// output EPCS_ASDO; input EPCS_DATA0; output EPCS_DCLK; output EPCS_NCSO; //////////// Accelerometer and EEPROM ////////// output G_SENSOR_CS_N; input G_SENSOR_INT; output I2C_SCLK; inout I2C_SDAT; //////////// ADC ////////// output ADC_CS_N; output ADC_SADDR; output ADC_SCLK; input ADC_SDAT; //////////// 2x13 GPIO Header ////////// inout [12:0] GPIO_2; input [2:0] GPIO_2_IN; //////////// GPIO_0, GPIO_0 connect to GPIO Default ////////// inout [33:0] GPIO_0_D; input [1:0] GPIO_0_IN; //////////// GPIO_0, GPIO_1 connect to GPIO Default ////////// inout [33:0] GPIO_1_D; input [1:0] GPIO_1_IN; //======================================================= // REG/WIRE declarations //======================================================= wire reset_n; reg [26:0] counter; reg [5:0] PWM_adj; reg [6:0] PWM_width; reg [7:0] LED; reg [33:0] GPIO_0_D; //======================================================= // Structural coding //======================================================= assign reset_n = KEY[0]; always @(posedge CLOCK_50 or negedge reset_n) begin if(!reset_n) begin counter <= 0; LED[0] <= 0; GPIO_0_D[2]<= 0; end else begin counter <= counter+1; PWM_width <= PWM_width[5:0]+ PWM_adj; if(counter[26]) begin PWM_adj <= counter[25:20]; end else begin PWM_adj <= ~ counter[25:20]; end LED[0] <= ~PWM_width[6]; LED[1] <= ~PWM_width[6]; LED[2] <= ~PWM_width[6]; LED[3] <= ~PWM_width[6]; LED[4] <= PWM_width[6]; LED[5] <= PWM_width[6]; LED[6] <= PWM_width[6]; LED[7] <= PWM_width[6]; GPIO_0_D[2]<= PWM_width[6]; end end endmodule
