13 years agoIs there any limitation of the sample clock of SignaltapII
I remember that this clock can't be higher than 175Mhz, am i right? But, I used much higher than 175MHz clock as the sample clock of SiganltapII in many cases.
However, i met a problem when i used 200Mhz clock as signaltapII's sample clock. It seems that this clock is too higher to be used as signaltapII's sample clock, for i change it to 100Mhz would be ok. The object device is ArriaGX. But i can use 200Mhz clock as signaltapII sample clock in CycloneII device on my another board. Why?
